2025 Maverick speedometer units
ronquist
Ron
ram diesel, vw jetta diesel
I can't see anywhere in the manual where I can change from Metric to Miles/hour for main speedometer. Is this not an option or if it is, I'd appreciate a tip where to find it
cwstnsko
Mesa, AZ and NE OR
2025 Maverick Lariat Hybrid AWD, 2023 Lightning Lariat
There’s a setting for secondary speedometer the changes the main speedometer to the alternate units and makes the normal units a smaller display. That seems the most useful for short term. For long term, I think you just go into general settings and change the units for the whole system.
ronquist
Ron
ronquist
Ron
thanks for your reply. I'll try the secondary speedometer first
Since you tried the owner's manual.
Here is a short video.
I hope it helps.
Good luck
canuckford
Lou
toronto ontario canada
2025 2.0L ECO, 2015 Transit T250
Did you create an account on ford.ca or ford.com in your case? There you can set your preferred Units, ie. Km, Temperature Celcius/F, and Pressure, PSI etc.
