2025 Maverick Specific accessories.
LSchicago
Lloyd
IL
What accessories specifically for 2025 are available? (Not items that fit 2024 or prior years) Dash items, grille, etc. Add any item here you know are offered for only 2025 and up. Looking to add more goodies on my 25.
scottjl
Midwest USA
'25 Lariat Eruption Green, 4k, BAP
can't think of any. there'd be no point in limiting yourself to just one model year, much less of a market. items would have to be limited to changes in the 2025's themselves which would be the front grill/lights. lack of the screen cubby in '25s means prior years have that nook that '25s don't.
LSchicago
LSchicago
Lloyd
IL
I know what was available for prior years. I have many items from my 23 that wouldn't fit my 25. I'm looking for items that are designed just for the 25's. Most of us know what fits 24 down.
Mean Green BP
Bruce
Covington, LA
2025 Lariat Eruption Green, 4K Tow, OEM Bed Extender & Light kit.
I just received the Diode Dynamics XPR LED bulbs for the backup lights and guess what? They are too large a diameter to fit into the housing assembly, also they have 2 small tabs on either side of the base which prevent the bulb from being inserted into the bulb socket. But stated they fit the 2025! Maybe a change from previous models.
retrojet
retrojet
WA
Space White Lariat
Just plug '2025 Ford Maverick accessories' into Amazon search, and go nutz!!! 🤑😉
LSchicago
LSchicago
Lloyd
IL
Not much for just 2025's yet. I haven't found any accessory parts that are just for 25's yet.
sg777
tracy
mississippi
2025 maverick tremor
Mabett has a lot of stuff that fits the 2025. I searched Amazon and the web when I bought my 2025. If you're looking for engine mods, lots has changed so not a lot carries over.
LSchicago
LSchicago
Lloyd
IL
Looking more for dash trim (25 ONLY) and front grille options. No engine mods, mine is a hybrid.
JollyRed
Derek
TN
Mazda3 GrandTouring Sport
You have to shave the plastic tabs off the bulbs’ sides to allow it to plug in. I used a box cutter to make it work m, it mentions it deep on DD’s product page.
Mean Green BP
Bruce
Covington, LA
Yes I saw the shaving of tabs parts but the diameter of these is too large to fit into the lamp assembly. They know of the issue but are trying to determine if the problem is a 2025 issue or a Lariat trim level issue.
LSchicago
LSchicago
Lloyd
IL
If I switch bulbs on mine, I will use ones from my LED store I closed. Easier than buying stuff that doesn't fit.
JollyRed
Derek
TN
Strange, I have a set of DD0052P in my 25 lariat for the reverse lights at the moment and they work great.
Mean Green BP
Bruce
Covington, LA
These were the XRP 800 lumens that won't fit. Yes I ordered 1 of the other 2 versions that do fit.
