15 inch wheels fit?
Maverickman74
Shane
Maui HI
Toyo AT 3 235 65 r17 fit look nice and work well. Very happy with them way better then the stock fx4 tires like night and day on loose stuff.
Stock was 225 65 r17 so the toyo is slightly wider only difference 235 vs 225
If you gi ko2 tires then it's 245 slightly wider then the optional tire size. People say they fit a bit tight though so could rub. Some people lift and go eith a 70 instead of a 65 that adds some ground clearance
Those arent MT tires sadly. It looks like Maxxis Bighorns do come in 245/70r17 and 255/65r17. Thats probably where im looking at once the 235 Falkens wear out. I have just had too many vehicles literally stuck in a slightly sloped sloshy grass area with AT tires. Even the KO2s to me are just a DD street tire. I wont even put em on my work truck.
Haha48
Scott
Canada bc
Well 12 degree hill wet grass and muddy it made it up no problem. Toyo also made a a mud terrain if you want just mud.
The hill was with toyo at3 they made it up the stock scorpions couldn't do the hill. It's all lose rock on a very steep side road think pea gravel 4low makes it up couldn't make it up would just sink in with scorpion tires the toyo ar3 made it up easy
Guv
Ford
According to this post from a different thread, it appears that the Maverick brake rotor's are too large in diameter to clear 16 wheels. I may check this out at some point and consider shaving a bit off the stock maverick rotors. This is putting the cart before the horse though, since I haven't put in my order yet!
Yeah, let's start reducing the brake capacity(y) BFG sells an A/T that is the correct size for the truck, not good enough?
Maverickman74
Shane
Maui HI
Love the Maverick offroad content! I get it ATs are pretty good. But big lug voids is the only way to go for me. Super Swamper TSL that fit I would get it.
