First some stats:
Now some unresolved issues (in no particular order):
The ride quality is overly stiff and could probably benefit from the Tremor dampers. However, the truck rides much better when near max payload capacity.
The factory sound system is very anemic and is primed for upgrading. It would be nice if there was a less complicated/expensive way to get the Sync 3 unit installed.
The seats could use more support for those with inseams >34." I've looked into the 10-way seats from the Escape, but it would be cost prohibitive and really wouldn't add much thigh support. More importantly, it would be nice to gain a few inches of legroom and/or have the pedals moved closer to the firewall - the transition from brake to gas during long city commutes can leave you with shin splints. Someone in the aftermarket could make a fortune supplying seat rail extensions.
Overall, the truck is ok. I have not had any issues that have left me stranded or caused an unscheduled visit to the dealer. The complaints listed above mirror many of the same complaints others have had and there isn't any real resolution to them...so I haven't even attempted to have the dealer "correct" them. It delivers the MPG as advertised and has come in quite handy for doing "truck things" that was normally relegated to an SUV.
- ~502 hours in the "on" position equals an average MPH of ~20, which is probably correct given all of the city driving...unfortunately.
- Truck calculated MPG - 46.9 (adjusted AFE bias at ~3k miles)
- Hand calculated MPG - 45.6
- Unscheduled maintenance - 0
- Scheduled maintenance - oil/filter and tire rotation (DIY)
- Grabby brakes at low speed, particularly during damp/winter conditions
- Terrible engine shutter during transition to electric-only mode, particularly noticeable at low speeds/coming to stop
- Occasionally when the engine shuts off to electric-only mode, it sounds like a rod is going to go through the block and it makes a terrible metallic/diesel sound
- Now that the weather is cooling back down, the dash/windshield rattle is back with a vengeance and is ridiculously annoying
- Radio (and climate control readout) continues to lag and needs to be reset, usually twice a month
- Wipers do not "park" correctly, causing an annoying squeak with every use, particularly on intermittent
- Heated steering wheel gets blazing hot for all of 5 minutes and then stops, despite being "on" (apparently normal)
