How does one get to the two front side marker lights to replace the bulbs please? Difficult to reach from the top. TIA
Watch the video on how to remove them. The first one I saw showed the pry method and it will at least give you a sense of how they come out so you are not just feeling around blindly behind them. Make sure to turn your wheels too. My big head wouldn't fit to see in there even with the wheels turned. And I wore gloves because that clip is not so forgiving.Thank you I will try that way
Definitely won’t pry from outside
Thank you
Hi was there a link to watch a video please? ThanksWatch the video on how to remove them. The first one I saw showed the pry method and it will at least give you a sense of how they come out so you are not just feeling around blindly behind them. Make sure to turn your wheels too. My big head wouldn't fit to see in there even with the wheels turned. And I wore gloves because that clip is not so forgiving.
I did and no problem but I used a plastic pry tool and was careful. Worked just fine.Thank you I will try that way
Thank you
