Maverick accessories, mods, how-to's on my Maverick
thecman
Clayton
Des Moines
Volkswagen CC
Nice Tonneau cover at a good price
TIPTOP Soft Roll-Up Tonneau Cover Truck Bed for 2022 2023 Ford Maverick 4.6ft Bed (54.4") | TP1 | https://a.co/d/aqaQXmp
It is the right fit, easy to install. The only thing are the clamps which come with the cover stick out a little bit. I may replace them with some C-clamps if they get in the way.
All in all I am pleased with the result.
Ford Maverick Maverick accessories, mods, how-to's on my Maverick IMG_9272
Barracuda340
Barracuda340
Abilene Tx
Test fit the metal bracket. Then I got to welding and grinding tonight. I will grind the other side cap tomorrow. This little project I think is going to turn out great.
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230507_190402
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230507_190407
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230507_195541
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230507_200935
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230507_200944
Barracuda340
Barracuda340
Abilene Tx
Well its finally in primer, and a dust cover made of textured black lexan to fit it. Black wrinkle finish will get sprayed tomorrow. Then I have to wire it in.
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230508_074102
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230508_074113
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230508_091355
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230508_160318
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230508_160443
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230508_160500
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230508_160643
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230508_160659
Barracuda340
Barracuda340
Abilene Tx
I temp mounted this and bolted it down tight for the first time. The rubber mount allows it a slight amount of "give". That's good because of vibration if it was really hard mounted. I cant wait to do the wrinkle black and mount it up for good. Anybody know what color the dome lamp wire is, and where I can locate it at the floor level? I dont want to chase it up into the ceiling just to do a wire hook up.
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230508_205548
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230508_205609
Barracuda340
Barracuda340
Abilene Tx
Black wrinkle engine paint sprayed and cured. Looks store bought IMHO. I cant wait to wire it up with a mercury switch, and install it this weekend.
While this project requires some special tools and special skills to accomplish, it shows something small that can be done.
The big question to ask, is this an accessory? Or is this a mod? It bolts on like an accessory, but is not something that can be store bought. So does that make it a mod?
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230509_102951
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230509_103011
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230509_103254
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230509_103311
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230509_103319
G19Tony
Tony
Las Vegas
2022 Ford Maverick XLT, 1994 Ford F150
That’s a mod, baby!
Barracuda340
Barracuda340
Abilene Tx
The latest on the under seat light. I modified a mercury switch housing to fit inside the light housing. I removed the switch and wires and cut the housing short. Put it back together with super glue, potted the end where the wires come out with silicone, and installed it with a little super glue.
This works best with an ohmmeter to see which angle is open, and which is closed. The .001 on the meter means the switch is closed. Note the angle of the switch in relation to the meter, and the switch in the lamp housing in relation to the meter
I twisted wires together on the bench to mess with it. Apparently the internal switching inside the light makes stay off once it loses power and is reconnected. This means I have to manually press the on buttons to light it up every time I lift the seat. And that's fine because it doesnt need to light up in the daytime. Also when I lower the seat the mercury switch will automatically turn it off.
The seat frame it bolts onto is a good ground. I ohmed that out as well. As such I will attach my negative ground wire to the light housing, then clean the housing up to bare metal where it touches the seat frame, and just run 1 wire to go to dome lamp power.
Heres pix.
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230509_202728
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230509_203330
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230509_203528
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230509_203534
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230509_204051
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230509_204211
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230509_204216
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230509_211730
Barracuda340
Barracuda340
Abilene Tx
I wired it up this morning inside the housing. The tilt switch is in series with the black ground wire. I added a case ground to the housing. My plan is to ground the light housing to the seat frame by contact, but also run a body ground. As stuff loosens up over time and wears sometimes grounds through hinges start to get a bit sketchy. This eliminates this problem.
I used 2 pin molex type connectors this way if ever have to remove the seat, or light I can simply unplug it. These connectors can handle 5 Amp draw. This light is about 1 Amp. I am using 2 conductor 22ga multistrand shielded cable, and braded nylon covering I plan to use where it comes out of the seat and runs along the floor behind it.
Light has been bench tested including the additional ground. No problem. Now I just have to run the wires in the cab and hook it all up.
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_113952
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_120345
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_122727
Barracuda340
Barracuda340
Abilene Tx
Ok I got it in the truck, wiring ran under back seat carpet. A straightened coat hangar with a hook works great for fishing wires. I eventually popped loose the plastic upholstery seam and had an easier time. I ran it underneath any metal framework not between that and the foam. This prevents the wires from being pinched between the metal and the foam. I still got to figure out how to remove the dang dome lamp. I watched a youtube tutorial on the side panel removal. If I can get the dome lamp out, I can fish the wires up to it.
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_131647
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_131653
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_131751
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_131846
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_132037
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_132101
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_132145
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_132708
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_133111
Barracuda340
Barracuda340
Abilene Tx
I figured out how to pop out the dome lamp. Used a butter knife to pop the clips and remove it. The green yellow wire is a nice constant dome light hot that times out after I think 15 minutes and turns off which is fine. It stays on long enough for me to rummage around and find whatever I need. I routed the wiring with the existing harness. Unpinned the wire from the connector and tied in my power wire. There was a convenient ground up there at the dome light opening with an 8mm bolt that holds the roof antenna. I used my trusty coat hanger wire snake to fish the wire above the headliner and route it back to the rear of the side curtain air bag. This works great. I drop the seat, it goes out by itself. I lift the seat, I manually select the color I want. White or red. The black wrinkle engine paint finish blends in well with the black carpet IMHO.
Heres pix.
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_141829
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_141849
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_151022
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_151034
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_151214
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_151316
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_152753
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_152757
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_153033
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_153419
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_153631
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_155627
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_155639
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_155644
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_161417
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_204703
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230510_204714
bayslarry69
Larry
ford bronco
Well, well, well, look who's living in the future with their fancy-schmancy light-up cup coasters! I bet your cups feel like royalty now, resting on those illuminated thrones. And don't even get me started on the multitude of colors! You could have a different color for every mood or occasion. Feeling blue? Turn on the blue light. Celebrating St. Patrick's Day? Green it is! The possibilities are endless.
But let's not forget the most important feature of these coasters - the ability to turn off when not in use. I mean, who wants to be sitting in a dark room with their cup coasters shining like a beacon of light? That would be like having a disco ball in a library. Not a good idea.
All in all, it sounds like you made a great purchase. And for only $15 and free shipping, you really can't go wrong. Who knows, maybe one day these coasters will be worth a fortune and you'll be sipping your cup of tea on a gold-plated coaster. One can dream, right?:LOL::ROFLMAO::ROFLMAO::ROFLMAO:
Barracuda340
Barracuda340
Abilene Tx
Yes they are great. I want to get the generic ones for my bedside table. Tap it and you get about 1 minute of light before it winks out. Just enough light and time to plug in my phone, set my glasses down and climb in.
mav_kev
PA
Mav
This is some next level stuff right here. Definitely not your average DIY! Well done!
Barracuda340
Barracuda340
Abilene Tx
I am an A&P mechanic that does a lot of aircraft sheetmetal fabrication, and heavy structural repair. I also do a lot of restoration sheetmetal on antique automobiles on the side, changing out floor pans, trunk floors, and rear quarter panel skins are pretty standard fare, so this is child's play for me.
Actually snaking and running the wiring and zip tying it to run with the OEM harness reminded me of some of the wiring mods we do on the aircraft I work on. The biggest 2 are retrofitting WiFi into commercial airliners, and adding power plug ins to the passenger seats for laptops and phones.
A lot of wiring, and power inverters have to be added for the seat power one, along with very specific locations for each inverter in the fuselage per the drawings. The wifi requires 5 antennas mounted in specific locations on the fuselage per the drawings, along with adding a location for boxes to the avionics racks.
We go in after its opened up, and mount all the brackets, mounts, antennas etc. When done, we roll our tool cabinets to the next aircraft. The avionics crew comes in and starts running wires and mounting all the equipment.
The more fun jobs are corroded seat tracks that have to be changed out, or bird strike damage requiring repair fabrication. I love those types of jobs.
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20171130_134719
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20211016_110609
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20211016_143549
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20220123_122409
Ford Maverick Maverick accessories, mods, how-to's on my Maverick Resized_20220321_110139(2)
Ford Maverick Maverick accessories, mods, how-to's on my Maverick Resized_20220321_184928(2)
Ford Maverick Maverick accessories, mods, how-to's on my Maverick Resized_20220321_184908(2)
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20200126_191810
Ford Maverick Maverick accessories, mods, how-to's on my Maverick received_684108373263937
Ford Maverick Maverick accessories, mods, how-to's on my Maverick received_564717538848213
Ford Maverick Maverick accessories, mods, how-to's on my Maverick received_726300348943265
Ford Maverick Maverick accessories, mods, how-to's on my Maverick received_942137156777287
Barracuda340
Barracuda340
Abilene Tx
Ok so a few more accessories arrived a couple days ago. I finally got the time to open them up. Sill plates are peel n stick so really nothing to review as far as how easy they are to do beyond making sure they are where you want them before you stick them down.
I like the brushed aluminum colored knobs on everything from the factory, and wondered why they didnt do likewise with the gear selector to make it all the same. I got a brushed aluminum cover, and decided to paint the knurled part black to try to make it appear as if the shift knob came that way. That is also peel n stick thin double sided tape. How well it sticks on there we shall see lol.
The sill plates are pretty heavy being made of stainless steel. With highly polished areas along with brushed areas. They were $30 w tax and shipped from Chinna as well as the knob trim which was around $10 with sales tax. Both were from Ebay.
Once I install and take more pix I will review further.
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230511_142559
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230511_142714
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230511_142719
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230511_143319
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230511_145412
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230511_145737
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230511_142838
