STARCOMMTREY1
Trey
Boligee, AL
First the bad things.
1. There is a rattle that has developed when I hit bumps. Potholes, railroad crossings, ect. I will be taking it back to the dealer to get them to locate that.
2. The radio is definitely buggy. Luckily I have found a fix for mine that has yet to fail, unplug or plug my phone into it. So far that has worked every time it has locked up.
3. There is no way to leave the truck in default eco mode. I am getting that muscle memory to change that at startup.
4. No indication of battery charge percentage. Not a biggie, but would like to have it.
5. Every so often the Ford Pass Start function misbehaves. A restart fixes that.
6. To open the hood you have to open the door. Major oversight in the design department. On the flop side, I love that you pull it twice to unlatch the hood. That makes it easier than looking for it on the grille. Also gives me a laugh when others go to looking for it!
Now to the general review/how to's
I have figured out how to manipulate the truck to get it to Electric only. The prerequisite is that the HVB have enough charge and you not be at highway speeds. 55 or less. Change the mode to Eco. Let off the gas and let the charge needle dive deep and then just ease back on it. Boom, you are in electric only mode.
The truck runs in ICE only more than I thought. The ICE is also WAAAAYYYY more fuel efficient than I thought. Highway speeds where I am hitting 37+ is straight ICE.
The EV coach shows you what is running. Gray only bar is ICE only. Gray/blue is true Hybrid. Blue is Electric. Charge can have either electric motor or ICE running depending on charge status of HVB.
If you let the truck sit a few days it will run ICE at the beginning. The HVB definitely drains while sitting. It will click randomly changing relays on various items. After a few miles it charges (this battery seems to charge really fast) and runs as advertised.
As far as mileage goes, I am averaging 39 on the dot combined with 80% Hwy. The last 800 I am averaging 40. My shortest trip has been 30 miles one way. This truck demands a different driving style. I am braking much sooner and letting the engine slow me down so I can charge as much battery as possible. I am easier on the throttle when I start up or I get to speed quickly and let off. The cruise is much better at fuel mileage than I am. In town this thing is killer. 45+ mpgs is normal.
The ride is the best truck ride I have ever had. It is even better than our Escape. It makes long trips much easier.
Not having Sync has opened my eyes to the best feature of this truck and I think the most overlooked(Other than the bottle openers). Using AA has made me never want sync again. Hit the voice and tell it to call the closes Lowes and it does. Ask it for the weather or new updates and it does. Tell it to take you to a random restaurant and it does. Even ask it what is 3+6/2 and it will tell you 6 every time. It has become more helpful than any OEM software could ever be. (AA even has some stupid games for when you are stuck waiting somewhere in your truck on the screen)
Power in the truck is NOT an issue. It hits 80 mph with ease and more than quick enough to help you avoid the other idiots on the road(I say other because we all have our idiot moments).
This truck is STABLE on wet roads. I have now driven on the interstate in torrential downpours twice. It handles it WELL. I have gotten it to hydroplane twice. Once at 74 and it came off plane in about 25 yards and did not get squirrely. I hit a bad puddle when it happened. My only issue was the cruise did not disconnect. Another was on a back road at about 60. I felt it and it went away just as fast. Just keep your speeds consistent with the weather and enjoy the ride.
The materials on the exterior are thin. I do think this truck will be easy to dent. The hood has a little shake at highway speeds, but that is due to how thin it is. This truck could not survive having struts. The hood would pull the same thing an old square body chevy does....
The storage in this truck is amazing. It takes this small cab and makes it unreal. Ford knocked it out of the park with this. It is setup perfectly. Put your phones up front, your cups in the cup holder, your pistol on your side, your credit card in the card slot(it fits perfectly) and your wallet in the spot next to that. Cant give Ford enough praise for the cabin setup. I wish they put that much thought into every cabin. It is ironic that they made every thing they could out of the cheapest cabin because they needed it to be desirable unlike the Lincolns where they know the owner is happy just to have a Lincoln.
Regular cleaning of the interior plastics will be needed. They seem to hold smudges and dirt easily. Just the downfall of the textured surfaces. Nothing a little Armor All cant fix. As all the reviewers said, even though it is cheap plastic it is done very well.
The lane keeping does have a weak vibration. It could be stronger but its still noticeable. The BLISS is the BEST I have seen yet. It tells you early and holds until the other vehicle is well within view. If you hit your turn signal it blinks rapidly to let you know not to change lanes. Those two things are done better than any other brand I have driven including Fords. I just wish the mirrors were bigger.
The reverse camera is fine. It works well and has decent lighting at night. LED reverse lights will make it even better.
I am surprised the XLT had auto for the climate control. I use it often and it works. It even lets you choose the max speed for the fan. That was new too.
I changed the oil at 1019 miles. It was clean. Looked almost like new. If the percentages hold the truck will get over 10k miles between changes. I had 95% life left at that change. Just remember the oil filter is Motorcraft 910s as most places do not have the mav hybrid in their system yet.
The auto dim is great except street lights and narrow streets with trees on either side can cause it to dim.
Big_T
T
2022 Maverick XL Hybrid
Number 6, the hood release is not a major oversight, it is designed that way on purpose due to the dual pull hood release, so the hood cannot be opened while driving.
STARCOMMTREY1
STARCOMMTREY1
Trey
Boligee, AL
It is a oversight for maintenance purposes. Cant tell you how many times I have had to open the hood while in the front seat. Heck, most quick lubes work like that too. I would honestly rather a latch under the hood than have to open the door to unlatch the hood.
Maverick2023
Kip
Atlanta, GA
Toyota Rav4
great review as usual. Any chance for more pics or interior? Can't get enough. This is like crack. I'm hooked.
maxpaine1337
South Carolina
F150
How's the interior cabin noise driving interstate speeds?
baldboy
Stephen
moody Alabama
Honda CRV.
WHAT IS ICE MODE,I AM SURE FROM WHAT I HAVE SEEN IN YOU COMMENTS THAT IT IS GAS ONLY.YOUR REVIEW OF THE HYBRID HAS BEEN VERY INFORMED THANKS SO MUCH FOR THE INFO ON THE H V B I TAKE IT THAT THIS IS ELECTRIC ONLY AT 55 OR LESS AND ALSO YOUR INFO ON ICE ONLY-GRAY AND BLUE IS TRUE HYBRID AND THE BLUE IS ELECTRIC AND I ALSO LOVED YOUR INFO ON HOW TO LET OFF THE GAS AND LET THE NEEDLE DIVE DEEP AND EASE BACK ON THE GAS.AND WHAT IS AA,I WOLD LOVE INFO ON THAT TO MAN YOU HAVE DONE A HELL OF A JOB SENDING THIS INFO TO US ALL THANK YOU VERY MUCH. STEVE ALSO FROM MOODY ALABAMA MAN WHOO-RA,CHERY-POINT AND GIGER.
STARCOMMTREY1
STARCOMMTREY1
Trey
Boligee, AL
Android Auto is AA. ICE is Internal Combustion Engine
STARCOMMTREY1
STARCOMMTREY1
Trey
Boligee, AL
Noticeable with no radio. Not worth mentioning if radio is running. What is noticeable is how quickly the cabin cools off or heats up if climate control is turned off. Near zero insulation
STARCOMMTREY1
STARCOMMTREY1
Trey
Boligee, AL
THANK YOU SO MUCH FOR THIS INFO IT WAS VERY HELPFULL/STEVE,ONCE A MARINE ALLWAYS A MARINE.BROTHERLY LOVE!
Marine.....that explains why you are yelling at me! HEHEHEHE.....thanks for your service brother. Hope you have a great 2022!
STARCOMMTREY1
STARCOMMTREY1
Trey
Boligee, AL
I can but pics dont do it justice......
STARCOMMTREY1
STARCOMMTREY1
Trey
Boligee, AL
That would be nice. With the extra bin I bet someone tries it
