Wireless CarPlay adapter, hidden
Crowman
Kevin
West Virginia
A mini Mazda, and a Dodge
i like the setup. all about small tweaks. question: i havent found a wireless carplay adapter yet that works properly. which one did you find that is that small and works?
I purchased this one on Amazon it works fine. It hooks up quick but I wouldn’t recommend it because the USB-C cable did not work. I went to target and had to spend another eight dollars and get one that did work. but the cable for USB to USB worked.
Ford Maverick Wireless CarPlay adapter, hidden image
Turts70
Jon
Airdrie, AB. CAN
ok; thanks for the feedback. I tried three quite expensive ones (over $100) and no-go. Maybe i need to thing cheaper!
Halo9x
Hal
Abilene, TX
Maverick XLT 2023
I have a 2024 Ford maverick lariat. It didn’t come with wireless CarPlay or ambient lighting for the tray. I added pictures below. The last photo shows there may be a slight risk to wire. I did not want to alter the parts, so I just left it as is.
Interesting solution. I used I-glue
Ford Maverick Wireless CarPlay adapter, hidden IMG_8294
Ford Maverick Wireless CarPlay adapter, hidden IMG_8295
Ford Maverick Wireless CarPlay adapter, hidden IMG_8296
Ford Maverick Wireless CarPlay adapter, hidden IMG_8298
Ford Maverick Wireless CarPlay adapter, hidden IMG_8297
Interesting solution. Mine wasn’t quite as elegant but still works. I used u-glue to stick my Carlinkit to underside of the storage area. I also added wireless charging. I used zip ties to corral the cables.
Ford Maverick Wireless CarPlay adapter, hidden IMG_0160
Ford Maverick Wireless CarPlay adapter, hidden IMG_0158
Ford Maverick Wireless CarPlay adapter, hidden IMG_0155
TN_Oldman
2023 Maverick
@Crowman So here's how mine looks. The wire goes left and wraps with the trim piece. My Motorola M1a is up inside behind the trim piece. 2 images showing wire and 1 showing it's not Velcro to the underside.
My M1a has worked very good and always seems to connect reliably.
Ford Maverick Wireless CarPlay adapter, hidden 20240522_162018
Ford Maverick Wireless CarPlay adapter, hidden 20240522_162007
Ford Maverick Wireless CarPlay adapter, hidden 20240522_162000
