Will TSW neptune 18” x 8 5x108 load capacity work?
Zed79
Zed
UP
22 XL AWD
If you jumped up to the 19" you can get a 1650 rating
1980NPT405108Z72NEPTUNEMATTE BRONZE19X85X1086.0740mm72.1022.93 lbs1650
Zed79
Zed
UP
22 XL AWD
Looks like spec on tires is Min load 102 so 1875
jsanch9
Javier
Los Angeles
24 Maverick XL Hybrid Cactus Grey
I sadly only like the grey
jsanch9
Javier
Los Angeles
i’m just wondering if the 30lbs is a big deal or if I should look for another wheel option I like.
Zed79
Zed
UP
22 XL AWD
1350 LB rating to 1875 is 525lb per wheel better than 25% less than ford calls for as minimum spec for the tires. edit to add for Load index 100 is 1764 still over 25% of the 1350.
I would not do it. Look what one class underrating tires did to ford and firestone with the ranger/ explorer in the late 90s.
Min load on Hybrid Lariat 2022 First Edition is 100.
