What are Plastic Plugs in Side of Bed for?
schal
Hal
Columbia, SC
2025 Ford Maverick XLT 2011 VW Jetta TDi Sportwagen
My Mav has 2 types of round plugs in the bed - the soft rubber ones & hard plastic ones, see photo.
I am planning to use one to route wire for bed lights. The rubber plug comes off easily, but are not placed where I want to route the wires.
The hard plastic ones are closer, but they seem to be hard to remove without breaking.
Anybody know what the plastic plugs are for? How to remove them? Thanks.
Ford Maverick What are Plastic Plugs in Side of Bed for? Round Bed Plugs
Cancunbadlands
Cancun
Cancun
Those plastic plugs in the bed of a Ford Maverick (including the Tremor) are primarily designed to protect the threaded mounting points for the Ford "FITS" system and other accessories.
The bed is pre-drilled and threaded to allow for various DIY or factory upgrades. The plugs keep dirt, water, and debris out of the threads so they don't rust or seize up. Common uses for these holes include:
Tie-down cleats or D-rings.
Bed extenders or cargo management rails.
Threaded inserts for 3D-printed accessories (the FITS system).
Cancunbadlands
Cancun
Cancun
The Flathead Slide Gently slide a thin flathead screwdriver under the edge of the cap. Twist slightly to pop it up.
The Trim Tool A plastic interior trim removal tool is the safest way to avoid scratching the paint or bed liner.
Pliers (Grip & Pull) If you don't care about reusing the plug, you can grab the head with pliers and pull straight out.
schal
Hal
Columbia, SC
Thanks for replies. Will give it a try to remove, post how wiring project went.
