This worked for me on my 2024 XL 2.0 and my uncle on his 2023 XLT Hybrid. Hope it might for you.
Restart your phone and do not go into the Ford Pass app. at 1st. Hook the phone to the truck, wifi preferred at the start but not necessary. Use Bluetooth or straight connect with a charger wire if wifi is not available. (If it is available at the start of the truck make sure after the 2 to 3 minutes, described below, that you to go to either Bluetooth or use the charging wire to the ubc port.) Start the truck and let it idle for about 2 to 3 minutes then drive it for at least 15 to 20 miles. Again, let it idle for about 2 minutes then unhook the phone from the truck -wifi-data-or plugged in. Turn off the truck and go back into the Ford Pass App. (This should be the 1st time you have been in the Ford Pass app. since turning your phone on.) Everything should be working at this point.
Hope this helps.
I now have a 2025 Xl 2.0 and had to do it on my last update for the tire pressure monitors results to show. Worked as well.
Thanks! I successfully used this on my 2023 EB Lariat.
