Two Face Color Changing Wheel Cleaner
Andrew.802
Andrew
Vermont
2025 Lariat Hybrid AWD
I was interested in trying this new wheel cleaner from Chmical guys. It says it's not recommended for painted and bar-polished wheels like matte wheels and polished aluminum wheels. (https://www.chemicalguys.com/products/two-face-color-changing-wheel-cleaner)
I know this may be a stupid question for some of you but I know nothing about rims. Would it be safe to use on the stock 18" rims for the Lariat? I am not suer if the aluminum is polished or if the black is a matte finish.
Ford Maverick Two Face Color Changing Wheel Cleaner Screenshot 2024-08-27 at 9.41.35 AM
Johnnycrouch
Charleston WV
2024 XLT HYBRID
Ford Maverick Two Face Color Changing Wheel Cleaner IMG_2046
I see it says not recommended for polished or matte finish.
A.Bursell
Stanwood, WA
No personal experience with this exact cleaner, but when I have tried other similar cleaners I have not been impressed. The "color change" is reacting to iron, which would typically be from brakes. Good idea, but I haven't found them to work as well as something like Adams Wheel and Tire Cleaner, even though it doesn't change color. YMMV of course.
EngineeredDetails
Andy
Vance, AL
2004 F150, 2016 Fusion, 2017 Explorer
North Coast Joe
NW Ohio
2024 Ford Maverick XLT Hybrid. 2022 Honda CR-V EX-L
I use Simple Green and Dawn dish detergent (only on the wheels) with a mild brush on tougher areas. Not only easy on the paint, finishes and such, both are easy on the environment. Since I use it from the first, there is very little crud accumulation. That way I don't have to use it every wash.
Chilipepper
Pete
Louisiana
Lincoln was
The warning is there for a reason. If you use the product on your rims and it ruins your rims it your on fault for the damaged finish. I use Meguiar's Gold Class Car Wash Shampoo and Conditioner Liquid on my truck
, tires, mud flaps and rims. Always get great results
jorl
FLORIDA
22 Mav HYB XLT
I tried that CG iron remover-worthless.cleans your wheels but so does dish detergent-remove iron? only if it just blew in on a North Wind
BeardedMarine
Darrin
Oklahoma
2023 Ford Maverick
This may be late, but I wouldn't use it. The lable says not for painted wheels. Clear coat is a transparent paint.
Jah.
Jah.
Central Florida
F150 original brake pads had terrible reddish brake dust . Hard to keep wheels clean . switched brake pads to ceramics and problem made much better . Just used brush and regular car wash soap to keep clean . No problem with brake dust on my Mav wheels yet . Of course I only have 8500 miles on it in 2 3/4 years . always garaged .
Ford Maverick Two Face Color Changing Wheel Cleaner 20221016_085836
Jersixmlp
Alex
2021 Ford F-150 Lariat
If you’re unsure about the finish, it’s safer to test a small spot first. For my own rims, I ended up using a cleaner from mustanghygiene.co.uk —works well on stock aluminum and doesn’t mess with matte or black finishes.
TORQUERULES
Ford
Just use a good mitt and car wash soap. Then you will not have to worry about the cleaner hurting your wheels. I never use wheel cleaner. Haven't ever.
