tremor bumper cover
GlennR
Glenn
2024 Mavarick Laredo off road
Does a tremor bumper cover fit a lariat?
Montana
With or without 4k?
I'm assuming you mean the bottom portion of the bumper? The plastic part, in which the Tremors have a different design?
GlennR
GlennR
Glenn
With or without 4k?
Yes my Cover is damaged and I thought I'd get the tremor one for a better departure angle
GlennR
GlennR
Glenn
yes the 4k hitch, I can do modification
Montana
You'd have to modify the intercooler mounts and angle to make the swap. One user has done it here. @Justin.23
*Edit, departure angle so you must mean the rear bumper? If so, I believe they are the same.
fossil
ernie
ohio
@Bwicka trimmed his rear. might give you some ideas.
Ford Maverick tremor bumper cover IMG_3083
Trevih
Hector
TX
23 Tremor
Are you referring to the front or rear cover?
The tow package has a larger radiator that would not make it a direct swap for the front cover. With modifications anything is possible but going down to the smaller radiator on your tow package to fit the front cover wouldnt be advised.
GlennR
GlennR
Glenn
I screwed up my rear cover on my lariat and looking for a tremor rear cover and hard to find. Any ideas?
Mike223556
PA
Ford Maverick 2023 XL
So are you saying that it is possible to directly swap a tremor bumper with a non-4k tow regular maverick? I haven’t found any photos of a tremor with no front bumper on to compare to.
Trevih
Hector
TX
23 Tremor
The cover would align with the headlamps and fenders.
It would not be a plug and play swap. You would have to swap components from the cooling for it to fit. The tremor has a different radiator than the other mavericks.
Added link to successful swap of tremor bumper to non tow fx4:
https://www.mavericktruckclub.com/f...er-swap-out-with-2022-fx4-front-bumper.25400/
