- First Name
- Dave
- Sep 17, 2025
- south Carolina
- 2025 Maverick XLT
- Engine
- 2.5L Hybrid
Road hazard damage. Can I get a replacement tire?
Are you asking if this should be covered under warranty? How could road damage possibly be Ford's fault?Road hazard damage. Can I get a replacement tire?
Good morning, Cancunbadlands.In AWD vehicles you should buy at least 2 new tires
That's correct, the "only 5 weeks" makes the differenceGood morning, Cancunbadlands.
Normally I would agree that at the very least, measure the tread on the tires to try and keep the same diameter tires on all 4 corners.
It is my thought that if the tires have only been used for 5 weeks, there should be minimal wear difference and should need only the repair or replacement of the offending tire, depending on how bad it is.
The OP should get/have a tire tread depth guage and verify their actual wear between all the tires and go from there...But I wouldn't think two tires would need to be replaced.
As for the original query, only the OP would know what his tire coverage says is covered and then look at the tire and what damaged the tire...if that isn't clear, a quick call to ask if the tire damage is or is not covered would confirm if they are out of pocket or not.
Have a good day,
Andy
