Tire sizing question 18x8.5 40mm
mco30mco
Canton MI
2022 Maverick XL 2022 Edge SEL
If my math is correct there would be 22 mm less room on the inside and 16 mm bump out on the outside.
Do you guys know if that 22 mm less on the inside will work or will it rub?
I’ve heard there is a little room to play with on the inside. Does anyone know how much room between stock wheel and touching? My car is suppose to arrive anytime and I have a chance to get a deal on wheels in either the size above or a wider 9 inch with 35 mm offset.
Thank you for any advice you can give
2slo2go
JAX Florida, Land of the Free
23 Mav, Area51 XLT Lux, Black Edition
I run a 245/70-17 with a +42mm offset and there is very very slight rub on the felt on full lock with compression. 1.5” level kit on front
