Switch back to digital speedometer?
Bobr_USMC
Leland, NC
2023 Maverick
I recently had service performed on my 2023, the drivers panel now displays several values including miles to empty, a time of use, etc. I am unable to find any info on changing it back to display digital speed. The manual says nothing. Any solutions?
Toddman45
Todd
St. Louis, MO
Should be able to scroll down 1 to digital speedometer. Maybe have to change a setting in the ipc if service effected the previous settings.
ABTremor
NC
2023 Tremor
Scrolling through the different display screens is done by pushing the OK button on the right side of the steering wheel up or down.
Ozarkbeard
Where the digital speedo setting is, may depend on the trim level you have. Posting your truck's Trim will help with instructions.
Bob captions under the pictures.
I hope it helps.
Ford Maverick Switch back to digital speedometer? IMG20241102141528
This should be your screen??
Ford Maverick Switch back to digital speedometer? IMG20241102141537
Push the menu button on the right.
Ford Maverick Switch back to digital speedometer? IMG20241102141633
It brings up this screen.
Ford Maverick Switch back to digital speedometer? IMG20241102141710
Push the OK button up till the white square is on digital speedometer.
Then push the OK button.
Ford Maverick Switch back to digital speedometer? IMG20241102141714
Voila.
I hope this helped.
Good Luck
Bobr_USMC
Leland, NC
2023 Maverick
Y'all were right on. I had selected the menu and was trying to do it that way, which of course is wrong. I thank you.
Semper Fi
