Steering wheel lock
Donald
Donald
Morehead City
2023 Ford Maverick XL
I installed a base plate today for use behind my motorhome. I went through the menu to put it into neutral tow mode. In this mode you turn the key off which I thought would lock the steering wheel but it doesn’t. I put it back in regular mode and it appears the steering wheel doesn’t lock at all. Can someone verify the hybrid steering wheel doesn’t lock?
RonFLA
Ron
O-Town
Isn’t it electric steering? No power, no steering.
Johnkn
MD
I installed a base plate today for use behind my motorhome. I went through the menu to put it into neutral tow mode. In this mode you turn the key off which I thought would lock the steering wheel Bit it doesn’t. I put it back in regular mode and it appears the steering wheel doesn’t lock at all. Can someone verify the hybrid steering wheel doesn’t lock?
It does not lock.
Good luck
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
Power steering doesn't work like that, exactly, at least by my understanding. Power steering is an assist giving you mechanical advantage. If you manually turn the wheel enough, it will still move, but it would be a lot of work.
Donald
Donald
Morehead City
Still learning this truck. I guess you are right. When turning the key to ready the wheel turns easily, so it must be electric steering. Good to know it doesn’t lock especially for towing.
