Steelie color change - options?
dawoogar
FL
Tacoma
Im cheap. I don't care for the steel color. What are my options, I don't want to paint them myself (didn't turn out great on my taco). Can you have steelies wrapped? Can I get cheap clip-on hub caps?
What are your guys plans for the steelies?
Chris_G
NOVA
C-6 Corvette
Can they be powder coated?
MAVRICK
Any
2024 XL
Powder Coating Black or Gun Metal Gray ...
Ford Maverick Steelie color change - options? Bronco Sport Steelies
Leand60
Clearwater FL
2023 Maverick XL Hybrid
I'm thinking old school trim rings.
dawoogar
FL
Tacoma
Id be fine with powder coating. How does that work, I take the truck somewhere they remove wheels and tires, powder coat and reinstall?
MAVRICK
Any
2024 XL
Is the photo black or gun metal gray? Just asking for clarification.
Also, is powder coating cheaper than painting?
Gun Metal Gray ... Powder Coating is better (more durable/ longer lasting) than Painting which is better than Plasti-Dipping that would only last 3-months before starting to peel-off.
Wire4money
Las Vegas
2005 Wrangler
I doubt powder coaters have tire machines. You would take them bare wheels. By the time you pay for removing tires, powder coating, then remount and balance, you could buy a nice set of aftermarket wheels.
VetteNZMan
Fred
NC
Too Many
When I looked at getting the steelies on my '87 Ranger media blasted and powder coated, must have called 5 places in NC and you are in at least $100 / wheel. That's you doing all the tire removal and I'm not sure how quick this can be done. Those wheels are something like 15" so I found steel trailer wheels at Summit Racing for $25 each shipped and that's what I have been running for a few years now. Look ok BUT they are not the roundest wheels - there is some high speed vibration due to their out of round state.
villageidiot
Southern California
many many in the past, none currently
im a steelies kinda guy.... and i don't mind spending money to swap colors. I'm also a mechanic by trade, and have access to whatever machinery i want to use, however, we don't do tires in house, but my tire guy will dismount/remount/balance for $15/tire. I'm my area it ranges from $50-70/wheel to have powder coated.
my wifes fiat 500 has steelies, i had them powder coated baby blue. i then took the lug bolts, chucked em in the lathe, center drilled them, and tapped them for an M6 thread. i then made little baby moon style center caps on the lathe and mill out of 1/4 inch aluminum plate. finished off with a clean double pin stripe.
Ford Maverick Steelie color change - options? fiat wheels
Ford Maverick Steelie color change - options? fiat stri
on my former 2018 honda fit, had them powdercoated charcoal metallic, and used 90's style chrome honda center caps, looked great. i also swapped to a different tire size and a stickier sportier tire.
Ford Maverick Steelie color change - options? fit wheels
Ford Maverick Steelie color change - options? honda fit
my 2020 ranger had steelies, they did a banger job with the sparkle silver, and nice center cap.
es7129
Ed
Long Island
For $100 you can either plastidip or vinyl wrap (spray) them. Just make sure you clean them and put down 5-7 light coats per wheel. If you don’t put down enough coats it can be a PITA to peel off the plastidip.
The only time I’ve had issues with peeling was when I needed to replace a flat tire; the tire mounting rubbed the edge clean.
