START-STOP MODULE MODIFICATION IN TREMOR 2025
catrikejoe
joe ramirez
MO
2025 maverick XL
Nothing happened. It modified the parameter, but the Start-Stop button stays on when the engine is turned on.
Might try doing a body module reboot after modifiction and i also found auto stop/start enabled under instrument module that i disabled maybe this will help you
A420QT
Marcelo
Argentina
Ford Maverick Tremor 2025
Sorry to bother you again. What do you mean by 'instrument module'?. I pressed the Start-Stop button, turned it off, but when I restarted the car, it came back on (with the BDCM module disabled).
catrikejoe
joe ramirez
MO
2025 maverick XL
I did not understand that last part. "I also went into the IP module and disabled it there also."
I disabled it in only one place, where you mentioned. BDCM module.
Without having the Forscan open in front of me i think the correct insturment module is called APIM if so you shoud beable to open same as the bdcm module
catrikejoe
joe ramirez
MO
2025 maverick XL
i will snap some pictures in about 45 min and post for you
Quest
IPC
A420QT
Marcelo
Argentina
Hope this helps
Thanks. But that only makes the Start-Stop notification on the Instrument Panel disappear. The Start-Stop button keeps staying on.
catrikejoe
joe ramirez
MO
2025 maverick XL
Hope this helps also i performed a bdycm module reboot and IPC reboot after performing changes than did the on demand test which will confirm no codes are set.
Ford Maverick START-STOP MODULE MODIFICATION IN TREMOR 2025 20260301_120153
Ford Maverick START-STOP MODULE MODIFICATION IN TREMOR 2025 20260301_120247
Rokan
Chicago
Ford Ranger
Hi. Does anyone know which module needs to be modified to set the Start-Stop to off by default?
There is a Spreadsheet on this forum that shows that the Start-Stop is in the PSCM module, but in the Tremor 2025 that option is not directly shown..
Thanks.
When I coded mine to completely off using for scan I remember having to do two modules. The first one was BCM, just shutting off/eliminating ASS then I had to go to the ABS module and code it if in there as well. It sounds odd I know but it has nothing to do with shutting off your abs brakes or anything I just had to shut it off in there after searching around on the internet this was the only way. I don’t know if this works in 25 or 26’s.
Cancunbadlands
Cancun
Cancun
F150 2.7 TT user
Kenneth
SE WI
2026 Maverick Tremor, 2017 F150 XL 2.7
Only had a Tremor for 4 days. But was looking for a start stop switch, our 2026 fresh build does not have "start stop", instead it has a stop hold button the keeps the brakes applied at a stop until the throttle is pressed. Much handier waiting at a stop sign on foot on the brake or stopped on a hill!
PS: My mistake it does have SS. I have been driving in sport mode and manual shifting for beak in.
My F150 used SS even in sport mode and displayed Sport on the dash.
