Ready for install.
JfredTrem
Justin
Maryland
23 Maverick XLT Tremor
All the parts and tools and bits needed to swap out the speakers just sitting in a box waiting...
Not on my Maverick.. just the weather to improve so I can actually do the work.
Went with the JBL.. Got em on Amazon for only 66
Sound deadening
Tools
Adaptors
All from Amazon.
Ford Maverick Ready for install. Snapchat-403122168
kkreit01
Korey
Olathe, KS
'22 Maverick, '17 Grand Cherokee Limited 4x4 V6
Have fun. I did my diver's side tonight. It took about 2 hrs. A lot of that time was, making my own speaker bracket out of 3/4" birch. The door panel is quite tight the first time, and I had a problem getting it back on as well. It's best to have window down when putting the panel back on. Now that I know what I'm doing, the passenger's side should be quick. I'll make the bracket before I start. I got Infinity Kappas, and they sounds great. I plan to unhook the OE dash tweeters, as I've never liked highs bouncing off the windshield.
Lordran_Hollow
Virginia
2017 Toyota 86 860 Edition
I wouldn't use any type of wood for your speaker brackets. Moisture is going to get into the interior of the door panel, and that will cause the speaker bracket to fail over time. Metra makes a speaker bracket adapter (82-5605) that is supposed to fit the Maverick. I haven't had a Maverick yet for a speaker install, but I picked up a 5605 for my own build when I eventually get my truck and the Morels I've been eying.
JfredTrem
JfredTrem
Justin
Maryland
Did mine today as well. Driver door took me about 40 min.. passenger side took me 15. Once you get the rear part of the door popped a swift pull works well. I used the metra adapters they worked great.
kkreit01
Korey
Olathe, KS
It's Birch. I'm not worried about it. It doesn't soak up water like MDF. Usually I coat with bedliner, but it's winter, and I wanted it done last night (didn't want to remove door panel again). Also, Crutchfields plastic adaptors are too thick. According to Crutchfield, these speakers do not fit. They fit fine when I made my own adaptor.
SharkBait
Sam
2023 Maverick XLT Hybrid
Sound deadening
Tools
Adaptors
All from Amazon.
I have these same speakers sitting around from a previous car, but Crutchfield says they won't fit the Maverick. Did you have any issues installing them?
JfredTrem
JfredTrem
Justin
Maryland
They fit great with the metra adapters.. Def a huge improvement. I drilled a hole in adapter to feed wires through
SharkBait
Sam
Perfect, thanks a lot. I just ordered a pair of the adapters, so hopefully I can get these installed this weekend.
