My 2022 Maverick Eco Boost with less than 13k miles developed a significant rattle when the weather turned cold this month. It was intermittent and occurred only when:
1. I first started it up
2. I first accelerated from a stop
3. As the transmission downshifted while slowing down. This occurred only for a second as it downshifted thru each gear.
The rattle seemed to be directly under the engine or the cab area.
I jacked up the truck and looked for possible causes. After looking around and checking for loose parts I shook the exhaust pipe as it came away from the exhaust manifold above. That appeared to be the rattle.
There is a set of 2 metal support rods that help stabilize the exhaust pipe as it comes down from the engine and enters the catalytic converter. The 2 rods rest on another metal bar that is fixed. Normally this does not seem to rattle but it appeared that the colder weather caused it to rattle.
I cut a small rubber 'grommet' out and it fit directly over the area of the 2 rods where it touches the fixed metal bar. This appears to have stopped the rattle. After a few days I checked to see whether the rubber was affected by the heat from the exhaust. I saw no affect on the grommets.
Has anyone else had a rattle like this develop on their Maverick?
