Question on accessory power
Jroehrer10
Jesse
PA
Ford Fusion
Hey all, picked up my mav yesterday and the first thing I did was put in a new dash cam. I got the rexing v1P - 4K. I have it powered by the 12 volt (cigarette lighter) in the front, my question is do these get continued power with the mav off? As of now it is staying on even after I shut down and lock up. Any help is appreciated!
bombast
Pennsyltucky
2022 Ford Maverick XL, Hybrid
I believe the lighter socket turns off after a couple minutes. If your camera stays on longer, check the settings. It may not be set to sleep on power off and is running on internal batteries.
Jroehrer10
Jesse
PA
Ford Fusion
Thank you! I found out that the camera runs for 10 minutes after power off. So the couple minutes of added time with the maverick plus those ten minutes were tripping me up every time i checked after 10-15 minutes.
WannaMav
Hawaii
2022 Maverick hybrid
You can adjust the time until shut-off via an option of the dashboard (not infotainment) screen.
Jroehrer10
Jesse
PA
Ford Fusion
I cannot seem to find this, do you know what it is under specifically?
WannaMav
Hawaii
AFAIK, it's a part of the Lighting options, as seen here:
g1zstar
NY
XL Hybrid Barebones
Be careful, It isn't 10 minutes exactly. I've had anywhere from 5 minutes to 30 minutes, and on the night that I woke up to a dead battery, 1 hour and 15 minutes if I recall correctly.
agmonaco
Tony
Pittsburgh
2024 Ford Maverick Hybrid
The 2024 maverick does not have the menu to control timeout on steering wheel controller. If anyone knows where the menu is for that on a 2024 lariat hybrid let me know.
