accessory wires in bed - no power
Decayed
yes
a car
So I finally got around to trying to install a 12v outlet in the bed using the accessory wires. No bueno they have no power and a voltmeter reads zero with the engine running. Aside from the fuse does anyone have suggestions as to what could cause this?
pnorwood54
paul
ALTO BLUE XTL AWD-4K-FX4-360
after trying 2 different parts i gave up
Ponypower50
New Lenox IL
2022 Maveriak Lariat, 2021 Mach e
I spotted a loose wire on the drivers side under rear wheel housing on top. I still don't know what it is, but maybe that's the connection for the outlet
Mabcim
Rochester, NY
22 Maverick Lariat 2.0 AWD; 20 Escape SEL 2.0 AWD
That’s the release for the gas door, that you are probably seeing.
Decayed
Decayed
yes
a car
svllcn
23 XLT Hybrid
Did you ever figure this out? I’m having the same problem with no power to the pigtail accessories. I checked all 20a fuses under the hood including #84, and they all look fine.
Decayed
Decayed
yes
a car
Bad fuse 84, The question is, why was the fuse blown when nothing was ever connected to it? Never did figure that out.
Try replacing the fuse anyway, you never know if it's a bad rather than blown fuse.
svllcn
23 XLT Hybrid
I’ll give that a shot. Thanks for the reply.
