Question about copilot 360 and copilot assist
ForeverWaiting
Pennsylvania
None
I received my Maverick recently and have been configuring various settings and was curious about a couple things.
With the blind spot monitoring is there any kind of audible sound when you have the turn signal on to change lanes with a vehicle in the blind spot or is it just the visual flashing light on the mirror.
Same question with the lane keep assist, is it just the visual light on the cluster or is there a way to set an audible beep when drifting out of lane (I know the steering wheel will vibrate)
Thanks!
deej
2023 Maverick 2.0 Lariat, AWD, 4K, Lux, BAP, HPR
Mine has only ever given me the visual flashing light for the blind spot monitoring, no audio, regardless of whether the turn signal is on or not (aside from the turn signal noise obviously).
No audible alarm for lane changing, although it does for the cross-traffic alert when reversing.
None for lane keep assist, either. Unsure if the related driver alertness warning has an audio cue as I haven't triggered that. The lane centering function will make a noise when it gets cancelled if it loses track of the lane markings
ForeverWaiting
Pennsylvania
None
@Darnon and @deej, thank you both. I thought that was the case, just wanted to double check I didn't miss something on the settings when going through the menus.
Dmthomp32
Doug
Charlotte
2023 Ford Maverick
It will also flash a coffee recommendation if it feels like you need to take a break from driving!! I found that kind of funny.
Billkowski
Huntsville, AL
2023 Maverick Lariat Tremor, 2021 Jeep Wrangler JL
I may be confusing this for some other function, but on mine the lane assist buzzes the steering wheel when I get close to the lane markers, I like that a lot better than my Canyon which would beep at me for that...found it irritating and turned it off.
