Pickup bed cubby/compartment
Jah.
Jah.
Central Florida
Went to dealer this am and they actually had cubby /compartment in stock . $45 + tax fordpass points . want to use up fordpass points . look up # NZ6B-E286C36-AD to find part and it has a different part # . funny they didn't have hb-1 bolts in stock . Will make due with what I have . didn't install yet .
Ford Maverick Pickup bed cubby/compartment 20231211_094740
Jah.
Jah.
Jah.
Central Florida
Installed cubby on drivers side/left side . not a big deal . will need 10 mm socket/wrench and T-30 bit/wrench to remove tie down holder for cubby to fit it in . I had additional 10 mm bolts in my bolt leftover container . otherwise you'll need to add later on . you could just use the 4 bolts from the cover that you have to remove . take one out to take to Ace or other small hardware store for comparison or order from dealer . so I have cubby o n both sides . keep tow strap , bungee and tie down straps in cubbies .
Don806
Don
SE Ohio
Amen on taking one of the bolts you have to a hardware store and match up..........the bolts from dealership were $15+ for a pkg of 4, and you only need 2. I think I found matching ones for 40¢ each.
FamousAmos
GAB
Maryland
2022 Maverick Hybrid XL
Although not needed, I ordered two extra bolts from the manufacturer of the cubby, just for appearances sake, to fill in the two extra holes. The bolts were fairly cheap. That said, I could not get them to screw into the two holes. I was afraid that I would snap them by trying too hard. I assume that it is Line-X spray in the holes that is blocking the way. So, I left the two holes empty. No one notices it, but me.
40caliber
forty
lost vegas
awd
If and when truck arrives I'll either remove mine or rename it.
RLmesc
Randy
Dubuque, Ia
18 Kia Sportage, 05 Porsche Boxster S, 85 Kawasaki
What he said but don’t wait for ford and their bolts. They only come in a pkg of four and are $5 each! Go to your hardware store where they can be had for less that a buck a piece.
