PCS issue
KCHahn
Keith
Colorado
Currently drive a 2001 Ford Range Edge 2WD
Checked FordPass recently, had following messages:
Check engine
Power train Control Module has detected an internal fault in a control module.
The power control system has detected the system power supply voltage is lower than desired.
Is this something covered by warranty??
Truck 2 1/2 weeks shy of 18 months. Picked up on 4/22/2022. With 5996 miles according to Ford Pass.
Daveo89
NJ
2018 F150 XLT
Everything is covered with the 3yr/36,000mi warranty which you're still under.
Sounds like the fault code set when the fuse from the DC/DC has an intermittent open that there's a SSM for.
Edit: April 22 delivery also means it's built in the affected range for the bad battery cable terminal to be a possible culprit as well depending on the specifics of the codes set/triggering.
RAnSD619
Ron
San Diego, CA
Toyota Camry, Honda Fit, Toyota Tacoma
Just curious. What is the affected build range?
