- First Name
- Ed
- Aug 15, 2021
- Arlington, TN
- 2022 Maverick Hybrid Lariat
- Engine
- 2.5L Hybrid
So I've got a Samsung S21. My previous phone was an S10 and before that I had an S7. Each had a bump up in charging speed, from the normal rate for a USB/microUSB(or whatever) to a USB/USB-C (fast charging) to my latest phone with it's "super fast" charging when using the 25W wall charger (USB-C/USB-C cord).
Will the Mav's USB-C ports give a "fast" or better charging speed for newer phones?
I've ordered a Lariat Hybrid w/Lux so it will have the standard outlet in the back if I want to use a wall charger to get the "super fast" charging, but I wondered if anyone had determined what charge rate the Mav will do when using the vehicle's USB-C ports.
Based on some other experience, if the Mav's port won't charge using the USB-C port to the "fast" level, then my phone most likely will lose battery power even if plugged in, albeit probably slower than if not plugged in. That's what happens when using either my 2012 Highlander's USB port or an older (3+ years) adapter for the 12V outlet. I have to use a Samsung 12V adapter that I got for my S10 to get a respectable/useful charging speed. It will charge my new phone in the 'fast' mode, but not the 'super fast' mode, which is fine.
