- First Name
- Luis
- Apr 4, 2022
- Riverview FL
- Website
- www.instagram.com
- White XLT
- Engine
- 2.0L EcoBoost
Niiice, looks bad assI used the maverick air bag yes
thanksNiiice, looks bad ass![]()
Got the mk8 off eBay for my XLT. How do I remove the steering wheel? I think I can figure everything else out. Gonna swap my old buttons onto the new wheel.
Disconnect negative terminal just in case safety first.
Remove front air bag
Theres only 1 bolt holding the steering wheel . And install the new one in .
Would be super easy to dye the stitching black. 10min job and you have a sporty all black wheel!That wheel is a huge upgrade. I don't love the red stitching. But something I may have to consider.
So the CAN/LIM would not work as a CC?Glad to see more people doing this! The LIM switch is slightly different than cruise control. Cruise control limits how low the car goes in speed - you can take your foot off the gas, and if cruise is on 75mph, it will keep going at 75 (I'm sure y'all already know that much.)
The LIM switch on the other hand is like the opposite. Set LIM to 75 and you can pedal to the metal - it won't go over 75. If you take your foot off the gas, it'll slow down, but in this case it's an upper speed LIMiter.
Apparently that's a lot more popular overseas!
No, and I had hoped that when I first bought the wheel - but the software recognizes the different switches, so even if you set cruise control to on in FORScan, the LIM switch won't work.So the CAN/LIM would not work as a CC?
I am looking at doing this upgrade, but I found the Ford Puma steering wheel on eBay. I haven't been able to confirm fitment, but I do see that some parts are interchangeable between the Puma, Fiesta and Focus.
Can anyone confirm if it fits correctly?
2020 MK2 Ford Puma Steering Wheel
What did you have to do to get the Maverick Airbag to be used? I attempted the install, but the airbag would not fit.Well i originally bought the weel so i can have the cruse control installed. Tried to enable it with forscan left side not working. But the wheel swap just swap the harness and was good to go heres how it looks . Ford fiesta wheel
which wheel you buy mine fit perfectly?What did you have to do to get the Maverick Airbag to be used? I attempted the install, but the airbag would not fit.
i belive if you follow the others on the forscan cruse control enable they recomend you use the escape switch. mine is just look at the rear part number and match it up on the forscan and it worked.So I need the left switch without limit?
