Maxzina-Maverick Kick Panel Available Now!
Maxzina
Maxzina
Diamond Sponsor
New Jersey
Current feedback from Mav owners: The driving side of the 2025 Tremor cannot be used. If there are owners of the Lobo and Lariat models, please feel free to contact me. Can you help us try it out for free to see if it's feasible?
MaverickGladiator
Jay
NC
2025 Maverick Lariat, Jeep Gladiator Rubicon
I have a 2025 Lariat, AWD, Hybrid. I would like to test if they fit. Does the driver side kick panel cover the OBD II port?
Maxzina
Maxzina
Diamond Sponsor
New Jersey
Of course sure!The OBD II port like this?This is sent to us by the owners of Tremor in 2025, and there will be a pipe.I found some OBI II ports on Youtube, and we have some gaps left, but we are unsure. You can send us your name, address, and phone number via private message, and we will arrange it for you.
MaverickGladiator
Jay
NC
Direct Message sent. Do you want me to post updated photos of fitment here, or create another thread?
Maxzina
Maxzina
Diamond Sponsor
New Jersey
You can directly send a post here. More intuitive to see if the 2025 lariat fits well.
jvcd28
San diego
Ford Maverick Tremor 2025
I'm the guy testing the panels on 2025 Tremor, I will try to upload more pictures by this weekend.
MaverickGladiator
Jay
NC
Received tonight. Testing fitment on my 2025 Lariat Hybrid AWD. Quality is nice. The back side of the kick panel has a soft vinyl material attached to it.
Underside of the dash looks to be same as other trims. I highlighted where the OBD-II port is, as well as the attachment points of the kick panel.
Driver Side:
OBD-II Port will be covered.
Passenger Side:
Overall impressions: Build quality is great. All hardware to install the kick panels are included. Fitment was spot on. It appears the underside of the dash of the 2025 Lariat Hybrid remains unchanged from other trims and year models. Location of vent cutouts are perfect and will not block the A/C.
I have one negative point. The Kick panel does block the OBD-II port located on the driver side. You will need to have a 10mm wrench handy with you at all times if you plan on utilizing the OBD-II port. However, those occasions are few and far between to really be concerned about it.
I highly recommend this product. I definitely needed it to cover the wires I had running to the fuse box under the passenger side dash. I hard-wired my auto-dim rear-view mirror and dash cam to the fuse box (fuse #3 and #20). Without these kick panels, a passenger could easily catch the wires with their feet and destroy the connections.
MaverickGladiator
Jay
NC
Maxzina
Maxzina
Diamond Sponsor
New Jersey
jvcd28
San diego
May be there's some variation from truck to truck ? - but on my '25 tremor the brake pedal is touching one side of the opening. I test fitted it again earlier and still same results. Or it could be just my truck :D I agree that it's a good product, just somehow doesn't fit mine .
enjoitheride
OH
It needs a cut out for the OBD port. First, so the panel doesn’t need removed everytime for access. Secondly, for those that run dash cams and pull power from the OBD. Just some suggestions. Cheers.
scottjl
Midwest USA
'25 Lariat Eruption Green, 4k, BAP
and for when you get service and they need the ODB port. they aren't going to want to be taking the cover off.
Maxzina
Maxzina
Diamond Sponsor
New Jersey
Nice idea!We will consider how to avoid this situation with the OBD-II port.
Maxzina
Maxzina
Diamond Sponsor
New Jersey
Due to the OBD-II port issue, we will currently upgrade it. Old products will be sold at half price. If you don't mind the issue with the driver's side OBD-II port, it's definitely worth buying!
https://www.amazon.com/promocode/A14QLMDXV886VT
promocode:9ONOFLKV
Now Price:$39.99
Start:2025-5-16 04:00 AM
End:2025-6-15 23:59 PM
Maxzina
Maxzina
Diamond Sponsor
New Jersey
The new kick panel has arrived.This product is compatible with the OBD-II port and will not affect the use of the OBD port. For the 2025 Tremor and Lobo models, it may still not be applicable as there may be a pipe blocking the driver's side.
Link:https://www.amazon.com/promocode/A1ALVRMGEBWEEJ
promocode:YV9S6R33
End at:9/13 23:59
Original price:$79.99
Now price:$63.99
