Maverick Hybrid no AC in neutral
computerpulse
Edward
2023 Ford Maverick
I went through a car wash the other day and put the truck in neutral and realise that the AC will not continue to work in neutral. Is there a way to activate the engine while in neutral so that the ACwill still run?
nandesho
Houston, TX
‘23 Hybrid Lariat BAP, '24 Hybrid XL
When the HV battery runs low it will stop the AC compressor. This is done to keep the HV battery from going below its normal operating voltage floor. You cannot override this protection (to my knowledge.) This feature has been present in every electric AC compressor Hybrid I've owned.
Although, it is hard to tell when it's going to happen in the Maverick because Ford removed HV battery gauges. Earlier Ford hybrids all had a battery gauge of some sort.
Edit- Because of the transmission design, charging can only occur in P, D and to a lesser extend R. It cannot charge the HV battery in neutral.
I would have assumed that it would be turned off during the up to 30 minutes of the "car wash neutral" to prevent the intake of water during the wash cycle. Doesn't AC run when in regular neutral? I'll have to check mine out.
Yes to the edit statement. This HV protection will be why the "Temporary Neutral Mode" is limited to 30 minutes. AC possibly may continue if HVB is over 40%. ?just guessing)
nandesho
Houston, TX
I do wonder if it is a SoC% or a voltage threshold.
From experience I've found that my 07 Escape Hybrid draws the line at 300 volts, at which point it will temporarily disable the HV battery and you're stuck for a few minutes. VERY embarrassing at the car wash.
lajlmt
Lance
Rio Rancho
‘23 Maverick XLT LUX
The last thing you want to do is roll down the window 😱 Seriously, us Hybrid Newbies need to know this stuff…
When in P I know for a fact that pushing the go pedal quite a bit will start the ice before the HVB drops to it's normal starting point for ice to be started. I will do it occasionally when I want to be sure HVB has at least the 40%(?) cutoff of ice! Will have to try neutral. Do not know if you would even want AC on particularly if fresh air intake is open?
Since you were apparently still in truck did you just put it in N or did you activate the UP TO 30 minutes Temporary Neutral ?
computerpulse
Edward
2023 Ford Maverick
That’s just weird, but there is a battery gauge that you can set on your dash console. I don’t this the AC will ever work in neutral. I forget what the console states when in neutral. I think the system naturally shuts down in neutral. In these current temperatures in Texas, the Maverick will heat up quickly going through the car wash.
computerpulse
Edward
2023 Ford Maverick
Just used the neutral
GPSMan
Many
AC will run in Neutral so long as the HV battery level is high enough.
"High enough" generally lasts only a few minutes.
The truck CANNOT recharge in neutral.
One reason why people neutral towing behind a motorhome have to physically put the truck in Park or Drive and run the truck every 6 hours or less. The other reason is to circulate lubrication.
nandesho
Houston, TX
Might need to drive for a few minutes with heavy amount of Regen to add as much as possible to HVB to add a few more minutes AC will run in N.
You can also use the Tow/Haul or Sport drive modes for a few miles coming up to a car wash to keep the ICE running more and charging the HV battery as much as possible.
YES! On way to car wash combine trip with my monthly drive in all modes then again in all modes with the L button pushed while testing the brakes also! 🥰!
