Maxzina
Maxzina
Diamond Sponsor
New Jersey
But can your provide the "inside" measurement I've indicated in the following?
Great questions, I have one of those tailgate shocks and I wondered if they would interfere when I saw the installation.
The measure is 1.6FT.The length of the expansion to the outside is the same as the length of the inside.
Maxzina
Maxzina
Diamond Sponsor
New Jersey
Given that this device uses the same mounting points as the tailgate shock, I don't see how they could work together.
We will try to see if we can work together later.
Maxzina
Maxzina
Diamond Sponsor
New Jersey
Maxzina
Maxzina
Diamond Sponsor
New Jersey
Great design! Very similar to my diy model from a couple of years ago! Made from a ladder and a shelf piece. Mounts to the lower tie down.
Wow!It's perfect!Your hands-on ability is extremely strong! Great DIY!!!
BigClydeLittleTruck
Clyde
This doesn't answer my original question but thanks for the attempt.
urwatuis
Melyssa
Vermont
2023 Maverick XL
I think you have your measurements wrong. 1.6' is about 20" which is the depth of the bed and the tailgate. Your device only extends to the mid point of the tailgate and not to the edge of the tailgate as it should. You need to make those legs longer. And as a table this device should be about 30" - 36" off the ground to be usable.
Dad
Great idea and I like how you used the Maverick's set mounting points for install. The price is reasonable, too. Hopefully, you'll get the tailgate dampener issue figured out. Appreciate your support and innovative products.
Jensen3
Louisville KY
2025 Maverick Lariat
Yeah, 19" is about chair height or a tall coffee table. Maybe some stout telescoping legs?
Maxzina
Maxzina
Diamond Sponsor
New Jersey
Thanks!We will shoot a video related to the tailgate dampener this afternoon.
  • Like
Reactions: Dad
Maxzina
Maxzina
Diamond Sponsor
New Jersey
Similar to camping tables and chairs, approximately the same height as this picture.About 19in.
urwatuis
Melyssa
Vermont
2023 Maverick XL
still only extends to the mid point of the tailgate and that is not 1.6ft of extension
Maxzina
Maxzina
Diamond Sponsor
New Jersey
The angle at which the extender flips into the interior of the bed is the height of the extender itself (19.1in), including all the lengths extended into it.
EffNo50
Central California
Yeah.If you need to convert, you need to loosen the screws and fix them in the corresponding position before tightening them again.
If you use the factory mounting holes it'll just flip from extender to divider, and not interfere with the tailgate dampener: (Note I did swap my mounts between sides L/R and the factory mount uses a backing plate to thread into so the tail lights have to be removed to set that plate. Also shown in this picture, I trimmed that plastic plug and moved my bed light switch there)
Maxzina
Maxzina
Diamond Sponsor
New Jersey
Hello everyone,
The tailgate assist can compatible with tailgate extender.
It should be noted that we only showed the installation steps of the upper bracket in the video (in order).
