Issue here after recall done.
Vtec87pr1
Antonio
Virginia
youtube.com
2022 XL Ford Maverick
If you guys get the abs module reprogram done you may experience a service light on after the recall . If anyone have done the recall let me know im trying to figure out if its a reprogram issue or i probably will need to put the truck back to old forscan abs reprogram
So to be clear you used FORScan presumably to enable the extra drive modes and now after the 4k brake light recall you have an ABS light? Have you gone back in with FORScan to check that the modified values are as expected? They may have been reset to the as-built values. Or need to be set back to as-built and then modified again.
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
i was worried but looks like everything its working fine . at first wrench light was on and had 4wd drive fault. i did the recall my self with ids since im a ford technician all i had to do was remove battery terminal and everything worked fine and cruse control still works . yes i added cruse control with forscan
georgeb
George
Temple Terrace
Maverick AWD 4k
how long did you need to disconnect the battery for?
Thanks!
georgeb
George
Temple Terrace
Maverick AWD 4k
Mine is apparently "bricked" while at the dealer - the dealer cant get any systems to respond / lots of lights on the dash.
Id love any thoughts you have on this - pretty sure they were performing the same update.
Thanks!
