Redneck Garage
Redneck Garage
Franklin TN
www.theredneckgarage.com
Will this activate the remote start buttons on the new fob if you don’t have them on your original fobs??
Show me a picture of your existing fobs
Redneck Garage
Redneck Garage
Franklin TN
Evidently yours didn't have the Lux Package ? Dang didnt even know they used these on the Lariat - Is yours a 22 or 23 ? The Fobs without remote start are a different frequency than the remote start ones. yours is this one - https://amzn.to/3kZfyr9
Ford Maverick How to Save $$ Money $$  on Keys by Programming Yourself -- From a Locksmith and Owner :) nostart_
Redneck Garage
Redneck Garage
Franklin TN
How many folks out there have a push button start WITHOUT remote start like Shakesbear ??
Shakesbear
J. R.
Yep. They split the 360 lux features on the 2023, so I opted out of the “ add on” remote start option and just remote start from the Ford Pass app 😉
Redneck Garage
Redneck Garage
Franklin TN
Yep. They split the 360 lux features on the 1023, so I opted out of the “ add on” remote start option and just remote start from the Ford Pass app 😉
ahhhh got it. the procedures are the same for adding that fob, I havent 100% tested it with Forscan however with the frequency being different Id say the 23 models dont have the chips for the 2 way communication needed for the fob based remote start. How much extra was it - just curious.
Shakesbear
J. R.
I think it was $200 😉
Beckybee
2022 Mav HEV
Any backup alternatives for this key? XLT Lux (pic borrowed from another post here)
Ford Maverick How to Save $$ Money $$  on Keys by Programming Yourself -- From a Locksmith and Owner :) 1675276884419
Redneck Garage
Redneck Garage
Franklin TN
ahh that was Fords Im pretty sure option trying to reduce chip usage. My Lariat suffers sometimes from the "deep sleep" issue but the fob remote start has always worked.
Timothyd
There has been many questions on the keys for our beloved trucks and as a locksmith I can say if you loose all your keys you will more than likely have to tow it back to the dealer until our software is updated. HOWEVER I have confirmed on bord programming works if you have the original two keys ( two programmed keys ) - you can program them yourself - that has been mentioned here before. Do this NOW !!! before you loose one of the two keys LOL.
On the XL or XLT trucks you can either add a flip remote or just a standard key ( possibly you might want to add two cheaper keys as a backup ) On the Lariat only the fob will work however the emergency key is not required. I thought I would put links to which keys to purchase and you can take them to a local locksmith just to have cut - as long as you maintain two extra you are in good shape adding in the future.
XL and XLT Keys - I have posted multiple links in case one is out of stock -
Remote headed Keys - $23.99-https://amzn.to/40xtAk7 or $29.95 https://amzn.to/3RpQJAH or $23.99 https://amzn.to/3WVGxAX
Plastic Headed Keys -
16.95 for 2 - https://amzn.to/3HNZe5h 43.21 Ford Factory Blank ( same Chip ) https://amzn.to/3jklzOD If you are wanting to do a "hide-a-key" this one is the one to use due to it being waterproof.
To program you insert the existing first key, turn on ignition, count to three, take out put in existing second key turn on ignition - count to three - take new third key - turn on ignition - leave on - you should hear a chirp and a message key was successful.
For the Lariat -
58.95 - https://amzn.to/3XT89b7 109.95 - 2 Pack - https://amzn.to/40m014U 37.95 - https://amzn.to/3XaDs0h For the Fob to work / be programmed it doesn't matter if the key is cut or not - it only opens the door if the battery is completely dead.
If your Fob does not have remote start for the 2023 Lariat it is this one - 38.99 - https://amzn.to/40ihWsZ
To program - open center console. Pull up felt cover - place first existing fob in depression - push start button ( without foot on brake ) ignition comes on- count to 5 - remove fob - push ignition off - put second existing fob in depression - push ignition on - count to five - remove fob - push ignition off. take new fob - put in depression push AND HOLD start button down - you should hear chirp and message - key programming successful.
All in all pretty simple procedures and a few dollars and effort now can save you hundreds later !
Thanks!
Redneck Garage
Redneck Garage
Franklin TN
Shakesbear
J. R.
Not sure how close you have to be for the fob to remote start the truck, but the ford pass remote start works from about anywhere with cell service. My truck is currently as far away from me as possible on the far end of the hotel parking lot while I’m on the 3rd floor opposite side of the hotel and it works great 🤠
Redneck Garage
Redneck Garage
Franklin TN
Id say you have to be within visual distance. When my truck goes into deep sleep it disables the ford pass remote. Most of the time the pass app is great tho :)
jsus
2022 Ford Escape Hybrid AWD
Factory remote start is 300 ft. Range is likely much shorter than that if you use the Perimeter Plus security system since that's using the standard fob which is much shorter range.
https://www.ford.com/support/how-tos/keys-and-locks/key-fob-and-remote-start/remote-start-system/
