This weekend I replaced all speakers, added sound deadening and foam rings. Took about four hours.
Then I hit a wall.
Installing a powered all-in-one subwoofer. I wanted to tap into the front speakers to get the cleanest bass without being handcuffed to Driver Only/All Occupants or Forscan change to the default equalizer, and finally connect to the sub’s high-level inputs.
I watched multiple videos, read multiple threads, checked and rechecked Crutchfield’s wiring diagram.
Driver side, above dead pedal I tapped blue (left +) and grey/brown (left -). Result, no sound at sub. It was getting some signal because it powered on. I then tapped the passenger side behind the A/C controls, tapped yellow/orange (right +) and green/brown (right -). Result, I have sound in the sub. Adjust the balance to the right and it stays, adjust to the left and it went silent.
I moved the driver side tap to the blue and grey/brown behind the A/C controls. Same results. I even used new taps and new speaker wire. I did notice if I only connect negative driver it gives sound, but adding the positive driver or left + by itself it cuts out.
I swapped from high-level input and installed a LOC. But same results Left RCA is no good, Right RCA is good.
I’m going to check tonight swapping RCAs left to right but I feel it’s a problem with my Left+. Also run the RCAs from another vehicle to mine and mine to that vehicle to isolate the issue.
Anyone ran into a similar situation?
Any troubleshooting advice?
Any tips?
I read somewhere about the Ford system protecting itself. Perhaps I damaged the Blue (left+) wire on my first tap and the system has shut off left+ to protect itself? The left door and tweeter are working.
Then I hit a wall.
Any tips?
