Fluid INSIDE speedometer plastic and rotary shifter
Ron Neal
Ron
SC
Sold Ranger
I am no auto valeting guy but does not look promising, if its on the inside when it dries it will show the spots, if its on the outside and will not wipe off then it may be etched in the clear plastic. Talk to the dealer and or get some professional advice plus your wipe down rag sure has a lot of lint or pet hair on it. It would drive me nuts if I couldn't fix it. Good luck and let us know what happens,:)
Rivers90
Ben
XLT Tremor, Miata
In the 303 lineup which product did you use?
Cubsfan24
Cubsfan24
You would need to sand and polish it and perhaps final clear coat it, much like one does with a clouded headlight.
I would try on the shift knob first. I am not sure I would do it on the instrument cover. I don't think you will ever get it as clear you would like it to be by doing a polishing resto. If you did decide to do it, I would mask off the cover and only expose the damaged section to the repair procedure.
Here is an example of a 2-step kit but you probably need a multi-step with sandpaper
Here is an aggressive multi-stage resto
Thanks for taking the time to explain this
Rivers90
Ben
XLT Tremor, Miata
Googling fogging of cage clusters from cleaning returns many results. Looks like all auto makes use the most delicate plastic for the gauge cluster.
Now I'm going to be paranoid about cleaning my gauge cluster. Lol
Suzukiridr14
Frank
Sarasota Florida
If this is actually the case, how would I remove it?
Leave it alone, you may make it worse. Live with it, and in a few years, trade it in on something else. It only bothers you now because it's a new vehicle. Time heals all wounds.
skyhawk
Airplanes motorcycles cars SUVs
Tailender
Will
Poconos
1995 F-250, 2011 Rogue, 2012 Jeep Liberty
I only use a micro fiber duster on my interior plastic. Maybe a little water if needed but rarely.
Cubsfan24
Cubsfan24
