- First Name
- Chris
- Aug 14, 2021
- San Diego, California
- JDM Fairlady Z TT (300zx), 350z, Maverick
- Engine
- 2.0L EcoBoost
I was reading the thread about putting Land Rover Evoque wheels on the Maverick and user TacoHolder pointed out that Ferrari 360 wheels were 5x108. I decided to do some digging and calculations in case anyone is tempted to try it. Below are the stock Maverick wheel specs vs the Ferrari 360 wheel specs. I got these numbers from pictures of a set of 360 Modena wheels for sale on eBay (link below). I still recommend doing your own research before dropping 3-4k on a set of Ferrari wheels. Additionally the 360 uses a staggered fitment and the rears may not provide enough clearance. With that being said, a set of 4 front wheels look like they would fit perfect (at least on paper) with a set of hub centric rings to fill the extra bore spacing. The only requirement to running these wheels is that they must have the Ferrari center caps because weird flex at your local cars and coffee.
Maverick Wheel Specs
Wheel Diameter: 17"
Wheel Width: 7"
Bolt pattern: 5x108
Offset:37.5mm
Center Bore: 63.4mm
Ferrari 360 Wheel Specs
Wheel Diameter: 18"
Wheel Width: Front 7.5" Rear 10"
Bolt Pattern: 5x108
Offset: Front 31.5mm Rear 38.95
Center Bore: 67.1mm
Clearance using front wheels
Inner Clearance: Identical to stock
Outer Clearance: Extends out an extra 12mm
Clearance using rear wheels
Inner Clearance: 39.5mm less inner clearance
Outer Clearance: Extends out an extra 36.5mm
eBay link for reference
https://www.ebay.com/itm/1642841320...6Ai8bpGY2LVl-s4HhKl15kluPm1TKOukaAsApEALw_wcB
Wheel Diameter: 17"
Wheel Width: 7"
Bolt pattern: 5x108
Offset:37.5mm
Center Bore: 63.4mm
Wheel Diameter: 18"
Bolt Pattern: 5x108
Center Bore: 67.1mm
