Fender Flares recommendations?
jussanuddername
Scott Township PA
2025 Ford Maverick XL
I just ordered mine yesterday. I'm getting the thinner ones, I don't think the bigger ones are a good fit.
GarryB
Has anybody added fender flares to their truck? I have not seen one with them, but think they might look very nice. If you have, can you post a picture.
I installed the Mabett Flares and have zero regrets. I reviewed them too. The reviews should be at the bottom of this thread.
Good luck!
RussCantrell
Russ
Mobile, AL
2025 Maverick XLT AWD
I went with Mabett. There's a number of choices here, but theirs is the one that looks the most "stock" to me. Could pass as being an OEM add-on for a higher trim level, which is what I like. Really fits the vehicle!
Cancunbadlands
Cancun
Cancun
Good luck!
Did you use any extra glue or just the 3M tape?!
rk06382
Robert
Alaska
2025 Velocity Blue Maverick Lariat Hybrid, 1990 Ford Ranger XLT SuperCab
I just wiped with Alcohol wipes first then installed all the buttons before removing the 3M red plastic strips. Then pressed the fender flares onto the Maverick.
Ford Maverick Fender Flares recommendations? Fender Flair a 20250701_194627[1]
kjbeggs
Kelly
Arlington, TX
2019 Ranger, 2022 Bronco
Mine are Maxzina, same as kjbeggs. super easy install.
Your sticker on the front flare looks more orange (and correct) than mine did. Mine were very yellow, which is why I pulled them off the second one of the corners started to peel up.
Did you replace the ones that came on yours? I've thought about maybe trying to 3D print something that matches, but really I'm fine without anything there.
BenK
Ben
Utah
2025 Maverick AWD Hybrid
The problem with flares:
They only look "right" with wheel offsets.
I installed the RC Flares, they stick out ~2", so I added 1.25 wheels spacers and they look just right.
The RC Flares are nice, but they are a PITA to install due to the rubber gasket slipping out of place during install; a second set of hands could help or better adhesive.
I'll post pics at some point ;)
Cocobean
Carol
New York
2023 Ford Maverick XL
Yea, they started to peel so I took them off… ok without them.
Not a fan of fake stuff but I liked the idea lol 🤔
Realtruck
Diamond Sponsor
Realtruck
Ocala FL
