Error Message on FordPass: Malfunction Indicator Lamp - Regulatory
Chicago Mike
Oklahoma
2022 Shadow Black Maverick Hybrid
Has anyone received this alert for their Hybrid?
I went to start it for work this AM and it was completely dead. I was able to jump start per the manual but immediately got this alert.
Ford Maverick Error Message on FordPass: Malfunction Indicator Lamp - Regulatory Alert
Error
Jeep
Here
Maverick Hybrid XLT Lux 360 Roof
Out of curiousity, how do you start the engine? With the key or remotely?
Ford Motor Company
Official Ford Account
Dearborn, mi
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.
Chicago Mike
Chicago Mike
Oklahoma
Never even tried starting remotely, only use push button..
Flomounier1
Los Angeles
2022 Ford Maverick Hybrid
That's what happened to my Maverick when it died. Yours must be affected by the wire harness issue or the software glitch issue causing it to die.
Chicago Mike
Chicago Mike
Oklahoma
When was your Maverick built? Sounds like they need to replace the battery wire. https://www.oemfordpartscheap.com/p...ery-Cable-Positive/119664100/LX6Z14290PA.html
It’s a Nov build, turns out it was the Ford Pass app, they replaced the battery and downloaded new software and still dead. Guy called me and said remove truck from the app. They kept it over the weekend and it was fine. The app was over communicating with the truck draining the battery. All is good so far. I also turned off the trucks Wi-Fi
