Sold: Illinois Engine cover 2.0
Lynyrd Skynyrd
22 Maverick
This is sold
This is the Lincoln version fits perfect.
$50 shipped to lower US
Ford Maverick Engine cover 2.0 475FC6A7-EB4D-4F94-AE1D-945BF49A0BA8
Ford Maverick Engine cover 2.0 E636C255-A728-42DB-8D21-1B95497B1161
KdeB
Kim
Delaware Water Gap, Pa.
2023 Maverick XLT, 2018 Subaru Forester, 1966 MGB
If you’d like to replace the Lincoln emblem with something Ecoboost-engine appropriate, I found these metal emblems that fit in the indented area of the Lincoln emblem EXACTLY.
$5,98 each on Amazon.
Chrome Finish Metal Emblem 2.0L Badge
Chrome Finish Metal Emblem Turbo Badge
Plastic Lincoln emblem easily removed (Two flat stud nuts on the back).
These badges come with adhesive strips — but they won’t hold it to the foam.
*** I discovered that if you remove the adhesive strip, you’ll find two bendable attachment tabs folded up. Just unfold them, hold the emblem over the space it’s going in, and push the tabs right through the foam.
The tabs aren’t quite as long as you’d like … but if you push down enough and squeeze the foam a little, the ends will come out the other side enough so you can bend them over to hold the badge in place.
(Fortunately the tabs are placed so they missed a thicker section of foam under the emblem spot. Sorry I didn’t get photos of it in place, but you’ll see when you do it what I mean.)
It also helps that these emblems fit nice and tight in the indented emblem spot, so as to “bite” into the foam at the corners a bit, which holds it in place. So not so critical that the tabs aren’t perfect.)
Here are photos of what they look like on the engine cover, and a photo showing the tabs extended from the back of the emblem.
Ford Maverick Engine cover 2.0 E63A4F8E-AD75-4FCD-B068-366B3141B1F6
Ford Maverick Engine cover 2.0 4737713D-A229-4614-9A33-584ADD6856EB
Ford Maverick Engine cover 2.0 418FDDAA-D24B-4E6B-861A-FF3215F7C1E8
Goosey
Chicago
2016 Mustang
How much picked up?
Cru_Jones
Ohio
Maverick Lariat 2.0 EcoBoast AWD
