Flood Ford 8 year / 125K 13 visits included
$1910
https://fordprotect.ford.com/premium-maintenance-plan
I've only seen some service intervals but I'm basing the ones below on Ford Escape info.
Below are my made up estimates of what services might cost at a dealer (they might be higher or lower depending on the dealer) -
Oil change (fluid/filter) (every 10K) $60 x 12 = $720
Engine Air Filter (every 30K) $20 x 4 = $80
Cabin Air Filter (every 20K) $20 x 6 = $120
Brake Fluid Flush (every 3 years) $100 x 3 = $300
Brake Pads (every 3 years) $250 x 2 = $500
Spark Plugs (every 100K) $200 x 1 = $200
Wiper Blades (every 2 years) 4 x $30 = $120
Drive Belts (same as coolant 150K) = $0 (period expires before needed)
Coolant fluid flush (every 200K) = NOT COVERED
Transmission fluid flush (every 150K) = NOT COVERED
Total Costs = $2,040
Now this could be higher if you need brakes replaced more often and if general costs go higher. For example a $60 oil change now might be $80 in 5 years.
I'm guessing the plan covers things that wear out prior to a service interval but I have some questions? For instance if your belt looks very worn and requires replacement at 100K will it be covered by the plan as it's shown in the coverage.
Items included in coverage -
I don't think I'd get this plan myself but I think these plans are interesting as you can calculate the value better than a warranty plan.
$1910
- Engine oil and filter changes
- Multi-point inspections
- Tire rotations
- Brake pads and linings
- Shock absorbers/struts
- Spark plugs
- Clutch discs
- Engine belts
- Engine coolant hoses, clamps and o-ring seals
- Wiper blades
