Austin
US
2024 XLT Hybrid
Hello everyone,
I've been trying to find good wireless charging solutions and I have yet to find any that actually look clean. I decided that I wanted to design my own model with no wiring visible, and I am happy to report that I was able to make that happen!
Ford Maverick Designed Custom MagSafe Charger Holder IMG_6623
First off, under the orange/black/blue mat where your phone sits, there is a compartment that can just be popped up with a flat edge such as a key. This makes it easy to wire so you don't need to drill into any trim. For the project, I started off by removing the trim that houses the USB ports and 12v by simply just pulling it towards me; it's only held in by four clips. From there, I grabbed some spare 16 AWG wire and tapped into the 12v socket to extend power to that cubby that I just talked about. The wires behind the 12v are a bit odd as there is a striped green cable and striped black cable. Green is hot for reference.
From there, I wired up one of these 12v adapters that accepts both USB A and USB C. I then drilled a small hole in the mat and was able to run my MagSafe charging cable through the popped off cover and connect it to the adapter with zero issues. The cover even closes up like it did before as there is a big enough gap. So far, I am having no issues at all with charging and I actually designed two models, one for people who want to hardwire like I did (edge wire slot), and one for people who just want to use the USB C port that they already have (top wire slot). The top wire slot does show a little bit of wire, but it's the next best thing to having no cables visible if you want to use the factory USB C port. I have these for sell on my Etsy if interested. I'm happy to answer any questions that you may have!
Update 5/4/26: I now design custom holders for ALL wireless chargers. If interested, check it out here!
Ford Maverick Designed Custom MagSafe Charger Holder edge wire slot
Ford Maverick Designed Custom MagSafe Charger Holder top wire slot
Edit: There has been quite a bit of demand so I am now selling complete units that support both iPhones and Androids. See here if interested:
https://rosewoodbyaustin.etsy.com/listing/4511296738
Ford Maverick Designed Custom MagSafe Charger Holder IMG_6841
Hanzzolo
Alberta
2025 Maverick Lariat
I just want someone to make a MagSafe charger that is plug and play with the existing wireless charger that’s in there. If I could swap that out that would be perfect. @MABETT. Get on it Ryan! lol.
Austin
US
2024 XLT Hybrid
I hear you. I've had numerous vehicles in the past with wireless chargers and they were awful. The phone would never stay in place, the charger would just quit charging after 20 minutes for no reason, and many other issues. That's why I wanted MagSafe to eliminate all these issues.
Austin
US
2024 XLT Hybrid
I also suggest for anyone who is interested, Woot is selling Magsafe Gen 1 chargers for $14.99
MABETT
Diamond Sponsor
Ryan
China
www.amazon.com
2023 MAVERICK XL
Thanks for the suggestion! That’s a really clever mod.
I’ve taken note of this and will definitely look into the feasibility.
Austin
US
2024 XLT Hybrid
Sadly looks like woot no longer has the magsafe chargers for $15. I will keep an eye on it and let anyone know if they reappear!
blitzoid
25 Hybrid AWD
TNFurb
Kelly
Nashville
‘23 Bronco Sport OB ‘24 Mav Lariat Hybrid
Hello everyone,
What model years is your design compatible with? The location of your USB ports looks different than my 24 Lariat
Austin
US
2024 XLT Hybrid
yours are slightly different because the lariat trim has push start whereas the non push starts have their usb ports on the left. My model works with push button as well, you’ll just have to tape the cable and run it along the top of the cubby if you want the wire mostly hidden.
JJach951
Jeremy
Murrieta, California
2023 Maverik XLT - received after 200 days
I actually have this sitting in My Etsy cart right now. Before I saw this. I know realize the difference between the two models. You don't have to answer the Etsy message I sent. Here is better
Will this work with the pixel snap qi2 puck. I just bought one for 19 bucks from best buy
Austin
US
2024 XLT Hybrid
Unfortunately this is only for MagSafe. However, if you can provide me the OD and thickness of the puck, I can easily modify this for you.
JJach951
Jeremy
This is according to Google I have not received it yet. I just ordered it last night
TNFurb
Kelly
Nashville
One more question. How snug is the mag safe puck inside your product? I’m just wondering if it pulls up easily when removing the phone or if it stays in place. I wouldn’t want to have to always reach down and take the puck off the back of the phone and re-insert it.
