Can someone check this tailgate part for me?
KdeB
Kim
Delaware Water Gap, Pa.
2023 Maverick XLT, 2018 Subaru Forester, 1966 MGB
Just brought our XLT back from having Line-X spray-in bedliner done. They did a GREAT job — no complaints. Covered the whole tailgate (Others have reported incomplete coverage here.) They removed all the tie-downs and rubber plugs, and plugged the threaded bolt holes before spraying. Very neat job.
THE QUESTION: We noticed this one place on the passenger-side tailgate hinge area where there is a white plastic bit showing under the painted metal on a round hinge bit.
It could be this is the way it’s supposed to be — we just hadn‘t noticed it before. (Only have had the truck four days…) It seems greased. Driver’s side doesn’t show this, but seems to be a bit different on that side.
Anyway — Could someone with a Mav check out this area for me on their truck and see if it looks like this? (And send a photo.) Just want to make sure the liner guys put the tailgate back on correctly, and that there’s not something missing here that got left behind.
Thanks!
Here’s the area I’m talking about… It’s the only white thing in these photos. A round piece of plastic under the painted metal hinge bit.
Ford Maverick Can someone check this tailgate part for me? F5EE532D-71C2-4B8B-9004-3437757FF502
Ford Maverick Can someone check this tailgate part for me? 4CE84976-94D6-451F-941B-11F898321D65
Beckybee
2022 Mav HEV
Just looked at mine. I have factory spray-in liner and it's exactly the same
fossil
ernie
ohio
nylon pivot bearing?
steel on steel would rust and screech like an old door hinge over time
KdeB
KdeB
Kim
Thanks! That’s what I wanted to know. Just jumped out at us, I guess, when giving the tailgate a look-see after the liner was sprayed in.
RonD
WA
2022 XT
Just the tailgate bushing. FL3Z-99430B23-A
KdeB
KdeB
Kim
Yep, clearly that is its purpose. Just didn‘t know if it was supposed to be exposed like that, or fully covered, as the drivers side is.
RonD
WA
2022 XT
One side is different because one side is able to be lifted out to remove the tailgate.
