I mount my XM antenna on the front center of the roof 1/2 inch above the windshield. The antenna wire can be fitted nicely behind the windshield with a credit card and it becomes COMPLETELY invisible. Run the antenna wire through the joint between the A pillar and front fender, then behind the door weather stripping, then thru a conveniently placed, factory cut, slit in the door weather strip midway down the door to under the dash.
Result, a completely invisible antenna wire WITHOUT having to disassemble and reassemble anything!
