Blend Date missing - where is it on window sticker?
jalbano2
JAMES
NY
2022 Maverick Lariat Lux, EB , 4k , FX4 , Moonroof
Maybe some one can help me. Last week 10/13/21 I received my window sticker and Ford site showed in production. I have looked over my window sticker thoroughly and can not find the blend date. Anyone else get a window sticker without a blend date?
Big_T
T
2022 Maverick XL Hybrid
Do you have a date here, below SPECIAL ORDER?
I believe this is the blend date, but I'm not 100% sure though as mine says 10 05 21, but my Maverick entered production and was fully built on 10 14 21 per the tracker.
That is indeed the blend date, highlighted in yellow.
  • Like
Reactions: JJC
jalbano2
jalbano2
JAMES
NY
Thank you Thank mine is 10/13 . I thought that was the invoice date. It still shows in production.
  • Like
Reactions: JJC
STARCOMMTREY1
Trey
Boligee, AL
Big_T
T
As Trey said above, the 3 day shutdown affected it. Because you're not a hybrid, you'll probably be built by Friday, if not then the first of next week.
Down
Jason
Scottsdale, AZ
22 Maverick/02 Z06 Vette
It prolly will for at least a bit longer, my blend date was 10/8 and I'm also still in production.
jalbano2
jalbano2
JAMES
NY
Thank you
jalbano2
jalbano2
JAMES
NY
THERE IS ANOTHER DATE BELOW YOU BLEND DATE. IT'S BELOW THE GREEN BOARDER LINE. IT SHOURL BE A DAY OR TWO AFTER.
Same day as the bled date.
jalbano2
jalbano2
JAMES
NY
Big_T
T
I'm not sure what that date means exactly. Mine originally was 10/5, then 10/13, just checked today and it's changed to today's date of 10/20. It might just represent the last time the window sticker was generated in Ford's system.
I believe you're correct. I have a saved pdf copy of my window sticker and that date at the very bottom is 9/30. I just pulled it up again from the tracker and it's 10/17.
jalbano2
jalbano2
JAMES
NY
I check earlier it was the same . Just checked now and it has today's date 10/20
teebandit2
terry
Cincinnati
2022 ford maverick fx4 xlt 4k tow 360 copilot
yep. mine has an in production with build week of 10/18
Down
Jason
Scottsdale, AZ
same boat here! Trying not to refresh the tracker all day.
Tracker hasn’t worked for me since yesterday, so I’ve avoided the “tracker refresh” trap today pretty easily. :LOL:
