Bedrug + Bedrails Question
Kingpin003
Ryan
WA
2024 Maverick Lariat - Azure Gray
Does anyone with a complete bedrug also have bedrails? It's it possible to use them in conjunction?
Looking into getting one- but would like to maintain bedrails- so I would appreciate insight from anyone who has tried.
Thanks!
oneinch
Stanton
SE Pennsylvania
'22 Maverick Lariat
When I bought my Maverick BedRug it only covered the bed floor and the tailgate. It doesn't go up the sides. I haven't looked, do they now cover the sides? In any case and if it does, you'll have no problem mounting the rails over the BedRug. The BedRug does cover the sides in my F150. It isn't a problem mounting the Boxlink brackets over the BedRug.
Kingpin003
Ryan
WA
Yeah, they make a full one that goes up the sides now. I think the sides attach to the bottom with a zipper or something. I was just worried it might be too thick to get secure.
Glad to hear it wasn't a problem on the F-150. I'm optimistic now. Thanks!
oneinch
Stanton
SE Pennsylvania
'22 Maverick Lariat
You might, but probably not, need longer bolts. The sides are only about 1/4" thick uncompressed. You'll compress them tightening the bolts. And yes, the sides will zip to the floor. That's how the F150 is.
RAnSD619
Ron
San Diego, CA
Toyota Camry, Honda Fit, Toyota Tacoma
Thanks OP. I’m also interested in the full BedRug and had the same questions. Also wondering if the BedRug forms so that you can still use the FlexBed notches?
Kingpin003
Ryan
WA
KCHahn
Keith
Colorado
Currently drive a 2001 Ford Range Edge 2WD
Here's mine, with full bedrug liner and bed rails. Let local shop do the work for me. They're an authorized dealer/installer. And the Backflip MX4 Tonneau cover fits perfectly as well. Quite satisfied with mine
Ford Maverick Bedrug + Bedrails Question IMG_20230522_144125411
Kingpin003
Ryan
WA
That is an awesome set up you have there! Hopefully mine ends up looking like that once my truck shows up.
Thanks so much for confirming that they work together!
KCHahn
Keith
Colorado
Form fitted to bed, flexbed works nicely.
Moby
Fort Erie
Hummer H3 sprinter van 65 chevy 11 Doka syncro
I have installed the full Bed Rug in two Mavericks now . I removed the tie down brackets first ,also made my own bedrails with airplane track . I just use an awl to poke a hole in the bed rug were the bolts go . One thing I would do differently is not cut out the holes for the rear access hatches . The bottom of the hole is to close to the zipper and hard to reinstall the plastic cover after.
RAnSD619
Ron
San Diego, CA
What’s the difference between classic and impact? I know the material difference (TPO vs no TPO) but what is the experience difference (i.e. is Impact more cushiony etc.)?
