Bed mounted outlet
dldsm7
dldsm7
Dan
Charleston
2012 Subaru Outback
For warranty I don’t think Ford would consider that an approved DIY item.
i can always wait 3 years then go to work on it 🤷‍♂️
  • Like
Reactions: Sam
Hot Runr Guy
West Chicago, IL
Take a look at the detailed pictures from the Chicago show. There is a picture with the rear seat backrest forward. Looks like the inverter is installed on driver side.
It should be easy to wire your own set up and get a higher quality inverter with extra outlets as a diy.
Keep in mind, as discussed earlier, the current 400W (AC output) inverter probably is already DC-input fused at 30-40 amps, if you are thinking something in the 1500-2000W (AC output) range, now you're talking battery cable direct wired to the battery, most likely best installed under the hood (on the 2.0 non-hybrid model)
HRG
medgar
SC
Honda Civic
HRG
Thanks for the valuable info and advice. I have an extra Renogy 700w inverter with 2 additional outlets due to powering my teardrop with a Jackery now to save some space and weight. I am hoping it fits behind the back and will give me some flexibility and options for my Dometic fridge etc.
Wire4money
Las Vegas
2005 Wrangler
That will be 60+ amps. Ensure you use a large wire and keep it close to the battery. 12v will have quite a bit of voltage drop if you don’t oversize the wiring.
