Bed cubby and power source installed
brnpttmn
MN
Nice. Do you have a link for the power point? I've installed the second cubby and would like to add power to it. This one looks to fit perfectly.
fastducky
fastducky
Miata and Titan
Nilight 4 in 1 ON OFF Charger Socket Panel Dual USB Charger Power Outlet LED Voltmeter Cigarette Lighter Socket LED On Off Rocker Toggle Switch for Truck Car Marine Boats RV, 2 Yeas Warranty https://a.co/d/ecF7g0W
Hdang1980
Elk Grove, CA
2022 Ford Maverick Hybrid
Finally got the cubby in the mail. Installed a 12v power source. USB, usbc and a 12v outlet with a power switch.
Location inside the cubby is 👍. Don't know if that's rain or you spraying water to highlight the advantage of said placement, but nevertheless it achieved its purpose. Great job.
Edge Haley
Edge
CARBONDALE-Atlanta
PORSCHE
Thanks for the perfect location (inside the CUBBY) !!! Spent hrs trying to figure out the best location so finally in desperation entered "AC plug installation on Ford Maverick cubby" and your (this link) showed up. My concerned was keeping dirt, water, etc off the ac panel ....your location IS perfect...Let the work begin. This'll make the installation easy. Thx
A plus is if you ever want to remove the AC panel, just glue another piece of plastic over the hole and it will not be seen from the outside.
