Back Up Camera image is blurry
Deleted member 42620
Guest
I had an eye exam last November. Just 6 months after the prior one. I kept complaining the TV looked blurry but my girlfriend said it looked fine to her. She has had glaucoma for 40 years so I thought maybe I should see the eye doctor. Turns out my astigmatism had gotten extremely worse in those 6 months. So it happens.
62 and I still see fine for distance. On the other hand, I think I single handedly keep the Viagra company in business 😂😂😂😂
Guest
ABMaverick,
yah…smartassery abounds on this forum. I think there are a lot of 12 year olds on here.
I just block them when I see them acting like A-holes.
It could be that water vapor got inside of your camera. To check for this hold an ice cube on the camera for several minutes to make the water condense against the inside of the lens (like condensation on a cold glass of iced tea) then tap on it several times to make the water run down to the bottom. Wipe the outside off then Check your backup cam view again to see if it’s better.
I doubt that this is the issue but it’s one thing to consider, my friend.
Maybe it’s a generational thing but I think a little friendly “ball breaking” is harmless and fun. I don’t see any actual mean comments on here.
Brianx
Pennsylvania
'24 Eco Boost XL Cactus Gray, tow bar, Co-Pilot
all i can say is i had a 2015 gmc sierra that had a terrible display. i replaced the camera, easy diy, and the result was a fantastic improvement.
Randorita
Randy
Mississippi
2021 Toyota RAV4, 2025 Maverick Lariat
You take Viagra for your vision? I find that hard to believe! 🥸
boxster03
michael
santa fe NM
2023 Maverick XL Area 51
How about - Hey its a Ford or Hey its a Maverick or Hey I will give you two chickens for it
tciotti2003
Tony
Arizona
2022 Lariat
Wow. Thanks for all the help. Really only one decent reply, and a bunch of insults. What a great community to be a part of. 🤦🏻‍♂️
That just started with mine in the last 2 days..Same blurryness. Gonna try and do a reset to see if that helps..
Gullzway
OK
1968 Ford Mustang Fastback
Those wavy lines could be from the screen protector you have on it. Were they there before?
