As Built question
phillipl8
Mississippi
2023 maverick
If I use the as built to reset the changes made, does it include updates that have been done since it was bought?
Tbone289
It depends on when you saved the data. Restoring the data will restore the module to the status it was in when you backed up. It's best to backup each module any time you make a change that works, so you can restore it to that exact point.
Ray-n-AVL
Ray
Asheville, NC
2024 XL Hybrid (Black), 2009 Yamaha V-Star Tourer
I found this application, As Built Explorer, that you can use to look at .ab files and even compare up to 4 different files. There is no install just run it from the folder you unzip it into. I ran it and got no messages from anti-virus or malwarebytes.
https://www.compulsivecode.com/Project_AsBuiltCompare.aspx
This is the search phrase it put in Google:
what program to use to open a ford .ab (as built) file
and this is what it returned
Ford Maverick As Built question Image 001
Hope this helps,
Ray
Tbone289
I would think no. As the name implies it's what was loaded when the truck was built.
Ray
The term "As built" in FORScan doesn't necessarily imply that. An "As built" backup is a backup of the information currently contained in the module you're backing up, as I explained in post #2. "As built configuration" describes the factory settings. The OP didn't specify which he was talking about.
Here's FORScan's description: " As soon as a module is changed, what is stored in it is no longer the factory As-Built, even though people still say “As-Built backup” for the live export. Ford publishes the factory record by VIN at motorcraftservice.com/AsBuilt. Your FORScan backup is something different: a snapshot of the module as it is today. "
