Anyone have a writeup or video to replace 12V EB Battery?
ndmiller
Noah
Atlanta
2024 Maverick XLT Azure Blue Metallic
I bought an Odyssey and went to do the swap removing negative, then positive, hold down, etc. The battery won't pull up, saw another video where someone indicates front will lift up but rear of 12V is held by tabs and the battery needs to slide out towards front of vehicle.
Anyone have a writeup or video or picture of what I can expect? This seems like it should be simple, yet disassembling the airbag and hood scoop could turn into a fiasco if I screw it up.
WildGrok
none
Should you post this in the Odyssey chats/sites?
" I bought an Odyssey "
Bwicka
Lakeside,ca.
Once you unplug the extra little plug on ground side , remove the factory hold down . Battery is just held with little lip on left side, but will wiggle and lift out . On older big trucks with similar hold downs , sometimes a clip on adapter( plastic tray) for the odyssey’s was required . But I think the maverick tray is small enough not to require it.
Samcat13
Gerald
The Villages Fla.
Maverick Lariat '24'
